headlight output
Old Oct 25, 2020 | 06:37 PM
wa-sleeper's Avatar
wa-sleeper
headlight output
Anyone else have a "problem" with the headlights seeming dim even in total dark? Its even worse in the rain. They aren't hazednover and I even bought the better bulbs. Is everyone changing to led bulbs? Or is there another fix?
Old Oct 26, 2020 | 10:53 PM
Lime1GT's Avatar
Lime1GT
No, everyone isn't changing to led.
Old Oct 27, 2020 | 11:35 AM
alloro's Avatar
alloro
That happens as we get older.
Have you checked what the voltage is at the lamps yet just to make sure there isn't an issue within the wiring?
Old Jan 25, 2021 | 03:48 PM
52Flthed's Avatar
52Flthed
Old Jan 25, 2021 | 04:36 PM
wa-sleeper's Avatar
wa-sleeper
I'm 34... haha. Well I also noticed while driving at night ( when actually noticeable) fir a second they get brighten then back to dim. Maybe 2 mins later brighter for a second then dimmer again. So im thinking wiring. But its annoying, it almost looks like I'm flashing my brights at people.
Old Jan 25, 2021 | 04:37 PM
wa-sleeper's Avatar
wa-sleeper
Originally Posted by 52Flthed
Whats all the "@@@" for?
Old Jan 25, 2021 | 06:33 PM
redfishtd's Avatar
redfishtd
You probably have a ground corrosion problem giving low voltage to lamps . Especially since they are changing sometimes because vibration is changing ground connection. .
Old Jan 26, 2021 | 09:08 AM
alloro's Avatar
alloro
Have you tried working the hi/low beam switch a few times just to try and clean-up the contacts?
Old Jan 26, 2021 | 09:09 AM
alloro's Avatar
alloro
Probable posted in the wrong forum or wrote something then decided to remove it, and since a user cannot delete a message he simple obliterated the text.
Old Jan 30, 2021 | 03:06 AM
Fifty150's Avatar
Fifty150
In old cars. It meant that your electrical system has a voltage drop. Could be battery, alternator, or even just bad wiring. Check the battery terminals. Then the wiring and connections.
I have LED headlights. Read all you can about them. Some people don't like them. Before LED were available, I used Hella lamps.
Roadbird
2004 - 2008 F150
Apr 8, 2020 09:04 PM
HookedOnFuel
Nov 26, 2007 10:47 PM
BroncoBoss351
1978 - 1996 Big Bronco
Sep 29, 2006 06:01 PM
VatoLoco
Aftermarket Products
20
Mar 31, 2005 10:12 AM
dslwraith
Jan 28, 2002 10:41 AM
