shimmy problem started
Old Oct 31, 2020 | 10:51 PM
41505379's Avatar
41505379
Our 1950 Ford F-3 has been restored for 22 some years. A couple of years ago at a Hershey show I bought a new pair of 17 x 7.00 Firestone heavy duty front tires to replace the ones I bought back 35 years ago for it. I was worried about their age. It had never had the shimmy problem before I put these new tires on. It takes all the fun out of driving it after hitting a pothole or rough area. If I had kept both of the old tires, I would put them back on to find out if for sure that the shimmy is caused by the new tires. I only kept one as a spare. Guess I could put the spare on and see what happens. any ideas or suggestions welcomed.
Old Oct 31, 2020 | 11:20 PM
fordf348's Avatar
fordf348
Have you had your tires balanced and the front end aligned?
Ed
near Philadelphia
Old Nov 1, 2020 | 07:38 PM
41505379's Avatar
41505379
I did check the toe in. It had none so I gave it 1/4 inch. I had not had the new tires balanced as they didn't seem to need it. Thank you for your reply.
Old Nov 2, 2020 | 11:56 AM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Are they the same size and pattern as the rears? If so you could try rotating the front's and rear's to see if the shimmy follows the wheels?????
Old Nov 2, 2020 | 01:49 PM
FortyNiner's Avatar
FortyNiner
So I am ignorant on this, how does one determine that tires don't need to be balanced?
Old Nov 2, 2020 | 01:53 PM
1956_F100's Avatar
1956_F100
You cannot determine if tires need balancing by looking at them.
Old Nov 2, 2020 | 01:55 PM
1956_F100's Avatar
1956_F100
Your new tires might be badly out of balance or out of round. The later of those cannot be fixed. Like I mentioned in my previous post, you cannot determine if a tire needs balancing by looking at it. If it's not a tire or wheel issue, I've seen badly worn steering boxes cause the issue you describe.
Old Nov 2, 2020 | 02:13 PM
wellcraft17's Avatar
wellcraft17
Toe in, according to several manuals I have, should be 1/16- 1/8”
Old Nov 2, 2020 | 02:45 PM
seaves46's Avatar
seaves46
Tires should ALWAYS be balanced after getting them fitted .
I'm surprised the tire fitter didn't automatically just do it without asking .
edzakory
Feb 8, 2018 12:14 PM
cc322
Jan 26, 2010 06:09 PM
ALBUQ F-1
16
May 12, 2008 03:54 PM
390fe
Feb 27, 2007 09:51 AM
fordsrgrt
Offroad & 4x4
Nov 18, 2005 08:29 PM
