96 Crank no start
Old Oct 31, 2020 | 11:53 AM
Sgtnubbs's Avatar
Sgtnubbs
96 Crank no start
The tach dont move when it cranks. Replaced the CPS, still nothing. Any ideas will help it's my work truck.
Old Oct 31, 2020 | 12:21 PM
BuddyBarnes's Avatar
BuddyBarnes
Check fuse # 22 under the hood. If blown unplug the fuel heater and replace fuse. If that is not it what brand cps? May have to check wire to cps.
Old Oct 31, 2020 | 01:55 PM
Sgtnubbs's Avatar
Sgtnubbs
Found and replaced the fuse already. How do I check the connector?
Old Oct 31, 2020 | 02:16 PM
farmert's Avatar
farmert
Did you unplug the fuel heater? If not the fuse could be blown again. The fuel bowl heater shorts out, and it is on the same circuit as the IDM.
Old Nov 7, 2020 | 12:44 AM
Chris1776's Avatar
Chris1776
Is your Cam Sensor working?
The truck won't start if it is bad.
Get the Ford sensor. Off-market ones can be bad , right off the shelf.
Old Nov 7, 2020 | 08:40 AM
96 OBS's Avatar
96 OBS
#2 on the fuel heater and the fuse. But I also think you’re correct to check the wires to the cps. What brand cps did you buy? If it’s anything other than motorcraft get rid of it and get a Ford one
stonemason
Jul 29, 2013 04:55 AM
Oslo
Feb 27, 2011 03:31 PM
westpsd
16
Mar 2, 2010 11:33 AM
LUMBERMAN
17
Dec 23, 2007 05:10 PM
kyoung
Aug 23, 2006 01:26 AM
