Sponsored by: Real Truck
Locking hubs issue..
Old Oct 31, 2020 | 08:01 AM
Chris Cobb's Avatar
Chris Cobb
So I bought this 2010 F350 and discovered there were no locking hubs on it.. So I dug up who the previous owner was and have asked lots of questions and he's been very forthcoming on all of it. So he told me he took the hubs out because or of them was rusting and he just never got around to buying new ones before he sold it. There is signs of rust on the driver side so I guess he's being truthful.
So I bought cheap hubs off Amazon and I'm getting nothing. I installed them in full locking position and the wheel will soon but the shaft behind the wheel does not.. So I assume these are junk hubs, bit I wanted to rest the 4x4 system before buying good hubs..
So now, what's the best bang for the buck with hubs? I don't want to spend a ton as I will hardly use 4x4, but with my business, I'll need it crossing people's lawns when wet in the mornings .
Is Warn still the best?
Thanks
Old Oct 31, 2020 | 10:53 AM
seville009's Avatar
seville009
i used Warn Premium manual hubs to replace the oem auto hubs in my 2006 F350 plow truck. They worked great; no issues.
Old Oct 31, 2020 | 12:11 PM
Chris Cobb's Avatar
Chris Cobb
Did it require any modifications? Can you send attach the part number by chance?
Thanks
Old Oct 31, 2020 | 01:11 PM
AK4x4's Avatar
AK4x4
Several good options;
https://milemarker.com/product/549-hubs/
https://www.warn.com/premium-locking...5-spline-62672
https://www.warn.com/super-duty-locking-hub-95070
Good Luck, Russ
Old Oct 31, 2020 | 04:11 PM
seville009's Avatar
seville009
Thanks
did not require any modifications. old hubs pulled off, new ones stuck in, cap off air lines. I’m no mechanic, and i was able to do it with ease.
part numbers may be different- web sites will match you to your vehicle, but the Warn 95070 link posted above by AK4x4 sounds familiar (looks like the hub i got)
this is a little thread i posted back when i did it
https://www.ford-trucks.com/forums/1...nual-hubs.html
Old Nov 3, 2020 | 12:53 PM
SnowPlowDriver's Avatar
SnowPlowDriver
I bought a set of oem last year from Tasca . they were abou $220. How did you not see they were missing? was there a hubcap on the wheels?
Old Nov 3, 2020 | 07:02 PM
rowingdude's Avatar
rowingdude
I'd go with the WARN manual hubs. There are a lot of things that can go wrong with the vacuum operated ones. The only downside is you'll have to get out in the snow.
Old Nov 3, 2020 | 07:06 PM
00t444e's Avatar
00t444e
If its snowing you can lock the hubs before you get in your truck.
Old Nov 3, 2020 | 07:40 PM
rowingdude's Avatar
rowingdude
Out of curiosity, if you use manual hubs and your shift on the fly solenoid is bad, do you need to replace that before your transfercase will work? I'm considering finding a manual transfercase to get rid of electronic crap;
Old Nov 3, 2020 | 07:46 PM
00t444e's Avatar
00t444e
If your refering to the PVH solenoid for the hubs then no you will just lock the hubs manually and shift the transfer case into 4x4 with the switch. If your talking about a solenoid that powers the shift motor on the transfer case then yes that will need to work for you to have 4x4. For 4x4 to work the hubs have to be locked, and the transfer case needs to be shifted into 4x4 either electronically if you have the switch or manually if you have the lever on the floor.
Old Nov 4, 2020 | 05:36 AM
Euroman's Avatar
Euroman
I've had Warn's for about 5 years now, no problems. I lock them in fall and unlock them in spring - or summer if I forget
high6
Mar 24, 2020 11:51 AM
MauleOne
Feb 8, 2012 05:18 PM
RippedF350
Feb 9, 2010 08:14 AM
ediaa
Dec 15, 2009 12:37 PM
jimmeyjack
Oct 23, 2005 11:34 PM
