Different 400 timing question
Old Oct 29, 2020 | 12:55 AM
black & blue 78/9's Avatar
black & blue 78/9
79 scab 4x4 400 c6
All summer the truck has started without a problem. The last 2-4 weeks, I'm sure the timing is messed up. When I go to start, cold or hot, it will crank but slow and sometimes like back pressure. All this week, definitely more back pressure and knock under load going up hill.
Until I can order a new timing chain and gears and install them, (working outdoors in Wyoming) can I turn the distributor back (counter clockwise) one/two degrees to stop the knock and relieve the back pressure at start up?
Is this the correct direction? Am I thinking this correctly or is my thoughts wrong and should do something else until I can install new set?
Next question, Is there a way to tell if a po has installed a straight up timing before dismantling or after dismantle while looking at the actual timing chain? I do know it has a double roller chain on it now.
Thanks for your help.
Old Oct 29, 2020 | 05:52 AM
boingk's Avatar
boingk
Hi mate, first thing I'd check is your batery - how old is it and what voltage under cranking? Stab some voltmeter prongs into the batter terminals and pop the hood. Place the meter where you can see it while cranking and check the voltage while doing so. You ideally want 12v or more, between 12v and 11v is poor but operational still, less than 11v needs replacement.
After that get a timing light. See what the initial and maximum timing readings are. Initial should be 6 degrees from memory, and max is about 30.
- boingk
Old Oct 29, 2020 | 09:13 AM
Tedster9's Avatar
Tedster9
The initial timing setting, the ignition timing generally, will never change for many many thousands of miles, unless, somebody has changed it. One possibility (if the ignition timing really is suddenly "out of whack") is that the distributor innard mechanicals are broken or defective, stuck, etc. You'll have to do some checks with a timing light to be sure.
It is possible to check where a camshaft is installed using a straight edge along the tops of the #1 valves, when they are exactly at split overlap on the compression stroke, check and see where the timing pointer falls in relation to the "0" TDC mark on the balancer, this gives a rough indication if the camshaft is running advanced or retarded. Not as precise a degree wheel but is useful to check camshaft phasing, maybe a timing set is worn badly, when troubleshooting engine strangeness.
Old Oct 29, 2020 | 09:34 AM
beartracks's Avatar
beartracks
Maybe a sheared pin in the dizzy drive gear or timing chain jumped.
Old Oct 29, 2020 | 10:29 AM
meangreen92's Avatar
meangreen92
Pop off the distributor cap and then crank the starter from under the hood, and observe which way the rotor turns. Probably counter clockwise.
If that is the case, then turning the dizzy counter clockwise will retard the ignition timing.
Check all of your battery cables and the cable to the starter too, because if they're corroded they will not allow enough current to pass to spin the starter at a proper speed.
Old Oct 29, 2020 | 12:25 PM
black & blue 78/9
Thanks for the answers. Cable ends are good. My other concern is now it knocks pretty good under load like going up a hill. 30-40mph city driving. Not ALWAYS but most and it did not over the summer. At least not that I noticed.
Old Oct 29, 2020 | 09:21 PM
Red Mercury's Avatar
Red Mercury
I am with beartracks on this one. I had a similar thing on my 1979 F150 with a 400. An experienced (older) mechanic at the local Ford dealership suggested checking if the roll pin in the distributor gear was sheared off. He was bang on, the roll pin had partially sheared off. The truck still ran, but not well. His explanation is that a piece of debris can get caught in the oil pump gears and shear the distributor drive gear roll pin.
emmakk
1978 - 1996 Big Bronco
20
Jan 15, 2012 01:47 AM
MikePacey
Mar 10, 2011 04:43 PM
200solomiles
Jan 10, 2008 09:59 AM
jdog34436
Dec 3, 2005 10:02 PM
fordguy76
Oct 29, 2002 06:42 PM
