No heat
Old Oct 28, 2020 | 07:04 PM
Bronc1's Avatar
Bronc1
No heat
2014' scab, 5.0, 183K
I turned on my heater this morning for the maybe third time this year and all I got was cold air. I turned the selector from floor to defrost and all was cold. AC worked fine two days ago. Any thoughts?
Old Oct 28, 2020 | 11:30 PM
Lime1GT's Avatar
Lime1GT
Blend air door or the actuator that turns it may may be broken.
Fairly common for the door to be broken. lots of youtube videos showing diagnosing and door replacement.
Old Oct 31, 2020 | 05:35 PM
Bronc1's Avatar
Bronc1
I took the actuator out so I could see it. I turned the key on switched on the climate control system, turned the temperature **** left and right and the actuator did nothing it didn't even make a noise. I opened the case turned the motor and all of the gears turned so no broken gears. What else could it be. Coolant level is good.
Old Oct 31, 2020 | 08:31 PM
Lime1GT's Avatar
Lime1GT
Maybe someone can post a wiring diagram for you to trace the circuit. Unfortunately I don't have one. Only other thing I can suggest is to check the fuses and relays involved in the heating circuit. Owners manual should list them. You may be able to switch the relay with another of the same part number that may be used in the fuse box to test.
Old Nov 1, 2020 | 05:06 PM
projectSHO89's Avatar
projectSHO89
Any thoughts?
1. Verify that you have HOT coolant flowing through the heater core. Without that, nothing else matters.
2 Which climate control system do you have? Without that basic and required information, no one can provide the correct diagrams and procedures.
Old Nov 1, 2020 | 08:57 PM
Bronc1's Avatar
Bronc1
I have a single zone system for an XLT not dual zone and temp is a manual adjustment. I was told the temp control may be bad, also, where would the relay be?
Old Nov 1, 2020 | 11:22 PM
greybrahms's Avatar
greybrahms
This is symptoms and steps I did to identify it was that actuator in my 2012 xlt with manual temp control.
Pull the fuse in passenger foot well, wait 30 seconds and reinstall. Have temp set to heat and warm up car and see if you get heat. If so, turn the temp **** to cooler(an 1/8 of turn is fine). Can you hear actuator keep going full cold when only moved a little bit? If yes, Likely the actuator is toast, fairly common issue. My Local dealer had part in stock, worst part was removal, but sounds like you’ve already got out. Price was less than $40.
Old Nov 2, 2020 | 07:10 AM
projectSHO89
There are no fuses or relays that can cause your symptom without also causing other extremely observable and more obvious symptoms.
Old Nov 2, 2020 | 09:23 AM
alloro's Avatar
alloro
Did you manually operate the blend door when you had the actuator off to see if the temperature changed?
Is the engine coming up to the correct temperature?
Old Nov 5, 2020 | 09:07 AM
steve(ill)'s Avatar
steve(ill)
so the actuator LOOKS GOOD buy does not move.. Makes you think no electrical supply ?... I would also verify that the MOTOR works... check voltage TOO the motor at the plug.
Old Nov 10, 2020 | 08:28 PM
Bronc1's Avatar
Bronc1
Problem solved. Apparently the actuator motor stopped working, I installed a new actuator and I now have heat. Thanks for all of your help.
scottsman87
Aug 20, 2014 10:45 AM
knapper64
Nov 13, 2010 09:33 AM
03_PSD
Oct 15, 2007 01:36 PM
killer4x4
Nov 6, 2001 02:54 AM
bronclover
Mar 11, 2001 11:17 PM
