Sound and insulation
Old Oct 28, 2020 | 03:29 PM
1966F100SC's Avatar
1966F100SC
Well I have been doing a lot of reading here and am getting mixed opinions on sound deadening.
i know the butyl mats are exceptional and I also have learned that 100% coverage is not needed. But I do not know how much I would need. So here is my plan for insulation and I need help making decisions for this:
rust cleaned up in cab and eliminated
surfaces covered with por15 where it’s needed
clean surfaces inside
place butyl backed product
place aluminum backed jute padding
(Jute on roof and floor and possibly in doors)
carpet and headliner installed
so the question is how much sq. Ft. Will I need if the butyl product? This will absorb vibrations, and the jute is for heat insulation. I hope that makes sense.
I have a 66 truck if that makes a difference. I will not buy dynamat because of the price and will not use peal n seal and take a risk of it pealing off and smelling. (It gets hot in Texas)
any help is greatly appreciated, it’s difficult to have a nice truck with budget fairly tight.
Old Oct 28, 2020 | 03:41 PM
jjriley97's Avatar
jjriley97
Stay clear of the peel and seal. The correct stuff is worth a little more money, but I agree Dynamat is crazy high. Go to Amazon and look up noico or kilmat 80 mil. Tons cheaper than dynamat, but just as effective. I use it for car audio installs.
Amazon Amazon
36 sq ft should give you everything you need at about $60. That should take care of the floor, back wall, roof, and doors of a single cab pickup.
Old Oct 28, 2020 | 04:16 PM
chiefdave's Avatar
chiefdave
Don't know the brand name of this product, foil backed self adhesive foam about 5/16" thick. Also used it on the top when headliner was replaced. So far it's been a good sound and heat barrier.
Old Oct 28, 2020 | 05:16 PM
resonateur's Avatar
resonateur
Should be easy to measure the surfaces you mentioned and calculate sq ft for each product you intend to use....buy a little extra for waste/cutting/fitting.
Old Oct 28, 2020 | 06:35 PM
1966F100SC's Avatar
1966F100SC
Those are the same two brands I have been looking at, and have read great things. I just wasn’t sure how much.
so with butyl and jute, and carpet the sound inside the cab will be quite nice right? Well as nice as an old truck will be? I can not hear anyone speak when doing over 30 it’s so loud
edit: also any opinions on Acc and lmc carpets?
Old Oct 29, 2020 | 05:45 AM
66ordie's Avatar
66ordie
did you have a layer under this? I used the MAT 66 and it seems to be fine, I just completed it and have the ability to go with a second layer but I never really thought about that, would I see a noticeable difference?
68shortbedmo
Aug 31, 2017 08:33 AM
4xfourdoorFloyd
Jan 11, 2012 05:49 PM
Ryank78shortbed
Sep 19, 2011 12:43 PM
whatthencuz
13
Sep 19, 2009 11:56 PM
75Player
Garage & Workshop
Oct 9, 2004 01:29 PM
