2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Up fitter Wiring and grounding Question
Old 10-25-2020, 12:33 AM
Ding126's Avatar
Ding126
Ding126 is offline
Wanted to know how you ground the accessories you have installed such as lighting. The truck manual says not to used the battery as a ground.
I assume you used the body or frame.
Looking for ideas since Im electrically illiterate
Thank you
Old 10-25-2020, 02:10 AM
2020STX250's Avatar
2020STX250
2020STX250 is offline
Thank you
On every accessory I've put on I run a ground to the nearest existing ground wire I can find on the frame. I'll ring lug the wire with a connecter big enough to go around the bolt and just place it directly on top of the factory ground wire.
Old 10-25-2020, 05:34 AM
Lamoon78's Avatar
Lamoon78
Lamoon78 is offline
Just look around there are grounds in numerous places already. Look on the fender well next to the batteries there will be one on both sides.
rbahr
Electrical Systems/Wiring
08-08-2020 02:15 PM
MikeIronTyson
05-29-2018 11:03 AM
hutch246
25
10-01-2012 10:20 AM
chrison600
04-23-2011 05:31 PM
triplecreek
03-08-2011 07:52 PM
Quick Reply: Up fitter Wiring and grounding Question
