Battery light
Old Oct 23, 2020 | 10:35 AM
marshall jarvis's Avatar
marshall jarvis
Battery light
Having trouble figuring out why my battery light is stay on, I’ve check the batteries and both are good, I’ve also used a multimeter to check if alternator is charging. Key off batteries are 13.1. Key on engine off they are 12.8. Key on engine running they are 14.6. Engine had been running for about 30 minutes prior to checking the batteries and charging. Can’t figure out why light stays on any help would be greatly appreciated!! I’m new to owning a diesel also so any advice is welcomed. Thank you in advance!
Old Oct 23, 2020 | 10:56 AM
oldbird1965's Avatar
oldbird1965
The small wire on top back of the alternator should be checked for tightness and be cleaned. I finally cut my connector off and put another connector on and haven't had a problem for a few years but I saw the light on the other day and will have to check mine again.
Old Oct 23, 2020 | 11:18 AM
BuddyBarnes's Avatar
BuddyBarnes
Oldbird is right dead on. Fix that little wire
Old Oct 23, 2020 | 12:11 PM
marshall jarvis
Thanks oldbird!!! Your advice worked I cleaned and made sure of tightness and the light is off now.
Old Oct 23, 2020 | 12:15 PM
BuddyBarnes
Don't ya just love an easy fix
Old Oct 23, 2020 | 04:06 PM
marshall jarvis
Yes!! An easy fix is always my favorite.
Old Oct 24, 2020 | 09:22 AM
oldbird1965
Once is a great while I can be of help! lol
Old Oct 24, 2020 | 09:40 AM
gtex's Avatar
gtex
almost as easy as electric tape over the indicator light
ShannonKincaid
Feb 23, 2020 08:40 AM
99FORD EXPY.
6.7L Power Stroke Diesel
Sep 2, 2019 06:22 AM
BEAL73
1997 - 2003 F150
13
May 15, 2018 04:05 PM
Leftyizme
May 1, 2014 10:34 PM
bitco
Jul 8, 2013 07:32 PM
