Summit ball and socket?
Old Oct 22, 2020 | 11:30 AM
F-250 restorer's Avatar
F-250 restorer
I was looking at these ball and socket connectors from Summit and wondered if anyone had used them, and what they thought about them, how they worked, problems? Thanks.
https://www.summitracing.com/parts/s...5-ss?rrec=true
Old Oct 22, 2020 | 11:35 AM
ford390gashog's Avatar
ford390gashog
I wouldn't even bother, they leak. If you want leak free go with the OEM style. Yes they are more expensive but often worth it.
https://shop.advanceautoparts.com/p/...AaAnJMEALw_wcB
Old Oct 22, 2020 | 08:54 PM
sokoloka's Avatar
sokoloka
Agreed. Big fan of OEM style. They just plain work.
Old Oct 22, 2020 | 09:24 PM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
I have been using this type for 20 years with no problem! I like to no gasket.
Old Oct 23, 2020 | 10:53 AM
F-250 restorer
I used the ball and socket with bolts at the muffler end, made by walker, about $10 each piece, and they are seriously strong. The flange is nearly 1/2" thick! At some point I will have to pull the headers and replace the standard collector flanges with a ball and socket connection. What I like about the summit system is that it looks clean, simple. But after seeing the 1/2" plate of the Walker flanges, I understand that is there because of the force needed to form a tight seal. I don't see how the summit flanges could equal that.
Mikec35
17
Mar 7, 2020 06:35 AM
"Phatman"
Jun 13, 2016 07:00 AM
SRBF150
Oct 27, 2015 12:40 PM
cdiddy
Jan 1, 2007 10:45 AM
04SilverSCFX4
2004 - 2008 F150
Aug 27, 2004 03:24 PM
