E pump which should I get?
Old Oct 21, 2020 | 11:26 AM
Farm4life's Avatar
Farm4life
Hi all new guy today, I have a 96 7.3 160/30 sticks, regulated return, fuel bowl delete, all the goods. I’ve been running a Aeromotive a1000 pump on it for about a yr and a half. It died on me a few months back, ordered a new one lasted 27 days and quit again. Talked to Aeromotive and they said to use a marine pump for it, I did, it lasted 25 days and quit!! Called them, had some words with them, they wouldn’t do anything about it.....so I need a pump again! But I feel I have a problem coming from the tank?! I haven’t looked but thinking my stock tube in the tank has broken off? Looking for opinions for a pump and issues in the tank pickup! Thank you for any help!
Old Oct 21, 2020 | 12:29 PM
97-psd's Avatar
97-psd
I would suggest a stock Bosch super duty electric pump. They are easy to find and have a warranty from any parts house.
If you are killing pumps I would check the wiring and make sure you don’t have a bad ground
Old Oct 21, 2020 | 03:47 PM
MJ79's Avatar
MJ79
I second checking your ground. I replaced two pumps before finding a bad ground.
Old Oct 22, 2020 | 04:43 AM
TheFecalFanatic's Avatar
TheFecalFanatic
I second the Bosch. Came from a knock off pump before putting the Bosch in and its night and day difference.
Old Oct 22, 2020 | 06:17 AM
JayTheCPA's Avatar
JayTheCPA
Welcome to FTE!!!
For reference purposes of brands to not use, in my other rig I used Walbro and Carter. They were good at one point, but had fallen off the recommendation list and both had short lives by the time I sold that truck (two years ago).
Agree with the others that Bosch has the best reputation at this time.
For the question about in-tank work, here is a good path to follow: https://www.ford-trucks.com/forums/1...light=tank+mod
Perhaps a Moderator will make it a stickey in the Tech section.
Old Oct 22, 2020 | 11:37 AM
Farm4life's Avatar
Farm4life
The Bosch pumps the 044?
Old Oct 22, 2020 | 11:38 AM
Farm4life's Avatar
Farm4life
Thank you all for the info. I will check on the ground, I never thought about that!
Old Oct 22, 2020 | 12:44 PM
Hit Man X's Avatar
Hit Man X
A1000 is a race pump last I recall as is the Bosch 044. Why would either be needed with 160/30 injectors?
I use a Walbro on my kit. Seems fine at this point.
Old Oct 22, 2020 | 04:12 PM
TheFecalFanatic
I used whatever part number riff raff has on their site for the bosch pump. Definitely isn't a race pump, though I wish it was
F81Z-9C407-AC
Old Oct 24, 2020 | 08:35 AM
fordman67's Avatar
fordman67
Walbro gsl392 has been great for me. No noise and supports my 250/200s like a boss.
maybe soon we will test on it again.
Old Nov 4, 2020 | 12:45 PM
Farm4life's Avatar
Farm4life
F81Z-9C407-AC
did you just buy the pump itself or the whole kit with wire harness and such?
Old Nov 4, 2020 | 06:06 PM
TheFecalFanatic
Only the pump itself. I reused everything else from my E fuel set up.
rockhi
Jul 3, 2012 06:27 PM
hotfuel
Dec 15, 2004 06:50 PM
kinderjw
Feb 28, 2004 06:54 PM
V10KLZZ71S
Garage & Workshop
Dec 21, 2002 06:13 PM
