Help identifying engine size
Old Oct 22, 2020 | 08:04 PM
matthewq4b's Avatar
matthewq4b
I concure this look like a cab swap on to an earlier frame. I would get the vin from the frame so you know exactly what you have..
Old Oct 22, 2020 | 08:17 PM
77highboy77's Avatar
77highboy77
If the engine and the front axle are original to the frame, they are from a '76. That's the only year with the open knuckle, disc brake front end and an FE, so most likely a 360 engine. It's definitely a highboy frame, and with '76-'77 having that front axle, '76 having an FE engine, and '77 having a 335-series engine, it should be easy to narrow it down; but as we see with this truck, things get swapped around over the years.
Andrew Laird
27
Aug 1, 2020 06:02 PM
SeanRiff
Apr 11, 2020 07:00 PM
KrenzyRyan
62
Dec 20, 2013 10:04 PM
cws10190
Jun 21, 2012 09:06 PM
AmongHidden
May 6, 2012 07:55 PM
