Anybody have thoughts on the new Banks rear differential cover? Sometimes it's hard to separate the snake oil from legitimate solutions but there are a couple features that seem like winners to me. Mainly for me the drain plug and sight glass fill level indicator. The cooling feature seems legit if it actually works. I had a Detroit TruTrac installed recently and it calls for conventional gear oil so I'll be changing it more often. Drain and fill sure would be nice rather than peeling the cover off and scraping the gasket material off every time.
There are a series of videos on YouTube about diff covers from Banks. Gale himself narrates And explains the Tech behind them. Pretty interesting watch. I believe the truck in the videos is a Dodge but if they went to that much trouble on the Ford model it should be jam-up.
Yeah I watched them and the cover for our trucks says they start shipping at the end of the month. Only thing I don't like so far is there is not way to get all of the fluid out with just a drain plug but the residual at the bottom I would guess won't make much difference. The plus is since it's o ring sealed it would be easy to pop off to clean out all of the residual old lube if one wanted to.
Have you thought about using a suction extractor to remove the differential fluid? They have flexible hoses that can get way down to the bottom.
Don’t have to remove the cover.
Yeah, I know. Then you’re left with one or no scoops. Above the Ford aluminum cover, I just don’t see the purpose. Admittedly skeptical of most aftermarket mo’ better items. Just my viewpoint, anyone can do what they want. It will be a good addition to your list.
Did you get your vibration issue solved?
Yeah pretty dumb of me. I guess of the guy who mounted and "balanced" my tires too. Had mud caked on the inside of the wheels in places from my long trips up to Deadhorse hunting. It got worse after the second trip. I had power washed everything too just must have been in places I didn't get to on the wheels. Funny that it must have been present when they wanted to balance my drive shaft because of a vibration starting at 45mph too.
That happens. One of the guys who worked in my shop used to go out into the Pinebarrens, went through an old gravel pit with clay mud. One of the spokes ended up with a pocket of mud caught and dried. He could not firgure it out until he went to re-balance the tires. It just didn't show.
I have to admit that I have had my cover off twice in 225k miles (then around 175k miles for the cover change to the PPE), but it (debris) just hasn't been an issue for me in that mileage.
The presence of a drain plug doesn't prevent an owner from a periodic cover removal on some frequency ...................
I like frequent fluid changes (even though I wasn't good at it with the differential at first), and I plan to remove the cover at 300k (if I ever get that far). I will have (planning to do so) drained and replaced fluids at least twice before reaching 300k (between 175k and 300k).
YMMV ....
I've been, and typically have changed at 50k, 100k, then 200k for our personal vehicles. The 50k was the most debris for my two Superdutys, deminishing afterwards. That should be typical with debris reduction, the gears are worn in.
At the testing facility, I had the schedule at 20k, but all the vehicles ran under GVW 90% of the time and rapid acceleration for half of the tests, doing fade resistance stops. We were lucky to get a Jeep to make it to 10k without wiping a gear set. Jeeps became change all fluids at 5k. Firebird/Camaro could get to 50k. Ford's 100k in general, with the exception of mid 80's F-150. I had an 800 number to call Dearborn to send another palletize axle.
The wear debris will alsways be dependent on the workload. And contamination dependent on water excursions.
