My '17 XL came equipped with halogen headlights and they have dimmed with time. Is there a reasonably price plug and play upgrade? I live in a rural area and the deer are really starting to move so would like a brighter light.
I think a better quality halogen is the cheap way out. I started reading about LED conversions and it appears to be a minor project with IMO some questionable details.
Take a look at PIAA or the Sylvania Silverstar Ultra.
Both of these brands as well as others offer upgraded and better halogen bulbs compared to the OEM bulbs which more than likely are based on doing a good job at the cheapest price.
Also, make sure your headlights are properly aimed.
Yah. The Sylvania higher-end bulbs are a pretty good alternative. They do burn hot, like any halogen. I got a set of perfect fit LEDs from Headlight Revolution. They went in about as easy as they could, and the beam pattern is close to perfect; maybe even slightly better than original. The ones I got only burn 15W; much cooler than halogen.
I've not had good luck with the Silverstar's in the past. They burn out very quickly IMO.
To the OP. The first thing one needs to do is to aim the headlights properly. They aren't adjusted very well from the factory. Mine were way high and the level made them even worse. Once adjusted they work great. With that being said, I, like JKBrad, will most likely be replacing them with some sort of LED replacement bulb. FWIW I have 99,600 miles on my 2015 and have not had to replace a single bulb.
replaced halogen bulbs with led bulbs in both my 2006 and 2011 F350 stock headlights (and reverse lights). Much better visibility. Even the reverse lights are much better (plowed with both, and can see much better backing up)
Aiming was the first thing I did. These late model light assemblies have a very sharp cutoff, almost like they were initially designed to use LED bulbs. It took me about 3 attempts to get them right and they were much better. 5 years, 55k miles and the factory bulbs are still working.
When looking at replacement bulbs, brightness should not be the overall determining factor.
i totally agree. i watched their videos and head to head they outshine and have a crisp pattern among being bright as well.
Up. The low beams were only lighting the road in right front of me And the high beams were too low to be effective on the road. Every truck is different and each one of my lights needed slightly different adjustment. In my opinion they are set a certain way, no matter how the truck is configured. Mine is a 157” WB with max tow, so the rear was 3 3/4” higher than the front when I got it. I adjusted them just below the point where I get flashed. Now there is a distinct difference between high and low. But the halogens are lacking. We now have 2 whicles with LED headlights and the F150 is really lacking right now.
I have seen quite a few on the road now with LED bulbs in the standard housing and it looks like a good combination. The advantage of using LED bulbs is that they are replaceable. The OEM LED headlights are not serviceable and need replaced entirely, housing and all, when there is a problem.
Agree.
I adjusted my 2011 F350 headlights a few years ago (bought it brand new in 2010); never thought of doing it before that.
Mine were too high; a little lowering resulted in a noticeable improvement.
I just turned my lights on in the garage shining against the wall to adjust them. Doesn’t take much movement of the adjustment screw to move them.
Gotcha. I think Ill adjust mine up when the time comes. I have the same truck as you and the front is like 2-3 inches lower in the front compared to the rear as well. Im mostly waiting to see what happens when I level it, as its gonna probably fix most of the issue. The halogen lights stink either way.
I had a 12 GMC and it too was pretty bad when it came to the headlight adjustment. Put a 2.5" level and voila no more issues lol
