Hey fellas ....coolant started leaking today. All hoses and clamps that i can see are good, no drips or any kind of wetness. After a while during idle and that engine got hot it started dripping/running down the underside of the oil pan. I cannot pinpoint exactly where its coming from. Hoping you guys may have an obvious answer and/or have experienced this one before . 2013 f150 5.0
Ok here's what i found. Removed skidplate for better look. First off its not the wye fitting by the thermostat. Posted a video and hope you can make heads or tales of it. Im lying on floor driver side...here is the link
What did you end up doing? My 2011 had a frost plug heater leaking behind the alternator. I had to pull the alternator and put in a brass plug in place of the heater. Of course the Y fittings were leaking, also so I replaced those O-rings while I was at it.
Did you figure out were your antifreeze was leaking from? I only asked because I had the same situation on my 13 5.0. It ended up being the water pump and it was totally shot. I had 80k on mine. It leaked once it was warm. Hope you figured it out. Just looked for my video when mine did it but of course I deleted it from my phone. Anyway hope it’s fixed now.
