Sponsored by: Real Truck
Diesel Fuel Addative
Old Oct 17, 2020 | 09:53 AM
elishaman's Avatar
elishaman
What is everyone using for additive in their diesel fuel? I am using Stanadyne Performance. Do you think there is a better option? 2013 f350
Old Oct 17, 2020 | 10:54 AM
Just Strokin's Avatar
Just Strokin
I run the Stanadyne Blue year round forumla and every other tank the Stanadyne lubricity. Does it help? Can't say, but sure doesn't hurt. I have been using it since day one of my truck.
You might do some searching in the 6.7 Forum for more info.
6.7L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Oct 17, 2020 | 03:29 PM
MountainManRobb's Avatar
MountainManRobb
My preference is the Hot Shot Secret line of products. Their Diesel Extreme product has impressed me when using it in a Duramax I used to drive for work. I ran a dose of it when I got my 7.3 a month ago, and have been using their Everyday Diesel Treatment at almost every fill up since then. I like the EDT because it comes in a 16ish OZ bottle and you just portion out an ounce at fill up and dump it in.
Old Oct 18, 2020 | 09:48 AM
Foxxx's Avatar
Foxxx
I use Power Service Diesel Kleen and their winter supplements in my 00, as well as in my "work truck" which is an M35A3 deuce and a half. also used them in my 88 IDI and have seen improvements in winter starting on all 3. Recently though, I have been using the Lucas cetane booster and it seems to perform about the same.
Old Oct 18, 2020 | 10:59 AM
Meat eater's Avatar
Meat eater
I use Archoil AR6200. I also use their diesel cleaner once a year. I use the cleaner when I’m planning a long trip towing heavy.
Here’s a link to both:
Amazon Amazon
Old Oct 18, 2020 | 01:01 PM
Dsimes's Avatar
Dsimes
My reference is Cold Pro Diesel additive.
Old Oct 18, 2020 | 06:43 PM
PatrickStapler's Avatar
PatrickStapler
I just purchased a 2015 with a 6.7L a month ago. I really like Lucas products. I use their products in my race car. Today I removed the Wix oil filter and Installed a Motorcraft filter and back filled with the Lucas synthetic oil treatment. I also added 8oz of the Lucas fuel treatment to the tank...which I just filled.
My question is how often are you supposed to use the fuel treatment products of any type.
Old Oct 19, 2020 | 11:32 AM
MountainManRobb
Some people say every fill up needs to have additive to help with lubricity. Maybe that is excessive, maybe not. You need to check the product you are using also, and see how often it is recommended. On the Hot Shot Secret products I use, the diesel extreme is only a maintenance product, they do not recommend every fill up use. I think I read somewhere it can lead to slightly higher than normal EGT's. But they make a product (Everyday Diesel Treatment) that is meant for every fill up use.
elishaman
52
Nov 14, 2020 09:14 PM
wb6anp
Dec 30, 2019 06:38 PM
1stpwstk
Apr 11, 2006 01:51 PM
donks
Nov 11, 2004 08:22 PM
