4r100 Codes PCM Issue?
Old Oct 16, 2020 | 09:36 AM
Chadwick46's Avatar
Chadwick46
Unhappy 4r100 Codes PCM Issue?
Working on a 2002 F-350 7.3 with 4r100. Right after start up the PCM throws the following codes:
P0750
P0755
P0743
P1754
P1747
These are all related to an "open circuit" or "short circuit" for the solenoids in the transmission. I cannot seem to resolve this problem. So far I have:
Replaced solenoid pack. No change.
Tested continuity in all wires on solenoid pack connector all the way to PCM. Confirmed as good.
Tested resistance on all wires on solenoid pack connector all the way to PCM. Confirmed as good.
Confirmed transmission has a good ground.
I don't know what to check next. These codes would occur randomly when driving at first and sometimes even go way during the same drive. Now it happens immediately on start up. I'm thinking something is wrong with the PCM? I don't want to jump to this conclusion if I missed something.
I'm not sure what to do next. Any help would be great.
Thanks
Chad
Old Oct 16, 2020 | 01:25 PM
Chadwick46's Avatar
Chadwick46
Update. Found a used PCM. Still have the same issue.
Old Oct 16, 2020 | 05:54 PM
Raygunn1's Avatar
Raygunn1
Have you tried the NSS or as ford calls it range selector. Yet?
Old Oct 16, 2020 | 06:03 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
You didn't mention checking the power feed to those solenoids as they all share one common 12v source. Positive voltage should be present in run and start at the solenoid body. The PCM supplies the ground path for each solenoid independently depending on operating conditions. Those codes set when 12v is not detected on the individual circuits when the PCM is powered-up and the solenoids are not commanded on.
Red with a yellow tracer on pins 1 and 12 at the transmission connector. Power from 20 amp fuse #2.23 fed from PCM power relay (which should be good since the vehicle runs).
Old Oct 16, 2020 | 06:33 PM
Chadwick46's Avatar
Chadwick46
You're on it!. I was not clear on what "hot" on start and run meant on the wiring diagram I guess. I initially had 5 volts and when I swapped PCMs it dropped to 0.2 volts (must have bumped it). I found one of the connectors on the fuse block lose. Never got locked in after the cab swap. Worked for a while until wiggled lose. More expensive than it needed to be but I learned alot! Problem solved. New solenoid pack, fresh fluid and a back up PCM.
Old Oct 16, 2020 | 07:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's not related in any way. It can't possibly be the problem. And it's called the Transmission Range Sensor (TRS.)
vegtoph
Dec 6, 2014 12:11 PM
DarrellinCeres
Mar 8, 2014 10:29 PM
Haines Hooter
Feb 25, 2013 05:48 PM
Lazy_pig
Dec 29, 2012 01:01 AM
mustang_gt_350
Nov 21, 2007 09:00 AM
