Transmission help
Old Oct 14, 2020 | 04:39 PM
77ford250's Avatar
77ford250
Transmission help
How can I tell if this motor is in neutral?
Old Oct 14, 2020 | 04:43 PM
ford390gashog's Avatar
ford390gashog
Well bring the lever all the up to park then two clicks down.
Old Oct 14, 2020 | 05:56 PM
77ford250's Avatar
77ford250
Transmission help
Does anyone know why that when I put the transmission and motor together the motor will not turn over to bolt the converter the flex plate is on correct and the plugs are out
Old Oct 14, 2020 | 05:59 PM
ford390gashog
Because the torque converter didn't seat and you probably jammed the pump. The torque converter has to be pushed and it should drop in three distinct points. How much clearance do you have between the TC and the flexplate when everything is assembled without the TC nuts on?
Old Oct 14, 2020 | 08:03 PM
77ford250's Avatar
77ford250
the converter and motor moves freely but once there together the motor won’t turn btw the motor had sit for maybe a year and half
Old Oct 14, 2020 | 09:21 PM
smle's Avatar
smle
Take it from someone who's done it. Your TC is not seated all the way into the pump. Which you've probably ruined by now. That's what I did.
Old Oct 14, 2020 | 09:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's because the torque converter isn't seated into the pump. Chances are that you need a new pump and torque converter. When they get jammed together like this it usually destroys both.
It doesn't matter if the trans is in neutral or not. The engine should spin no matter what gear the trans is in. And if the engine isn't running there are only two possible gears in the trans, no matter where the shift lever is. Park works, and everything else is neutral. And the engine can spin in every position unless the torque converter is jammed against the pump because it isn't seated into the pump.
QuantumCarburetor
Apr 15, 2020 02:22 AM
BORDERBUM
Missouri Chapter
82
Jan 31, 2016 05:40 PM
Casper Geist
1947 and Older Ford Trucks
18
Sep 21, 2012 12:08 PM
Snowking
24
Aug 27, 2009 08:14 AM
5 Star Tuning
South Carolina Chapter
Dec 23, 2007 06:37 PM
