Voltage Codes
Old Oct 13, 2020 | 09:02 AM
rclc's Avatar
rclc
Trailering
Voltage Codes
In doing a OBD1 test two codes came up 121 & 122. 121 closed throttle voltage higher or lower, 122 throttle position sensor below minimum voltage. Engine light on, TPS was just replaced and up came these codes. After TPS replaced engine RPM would not go below 1100rpm, and engine hesitated when quick increase of throttle. I have a bad feeling new TPS is bad as engine was not performing in this situation.
Old Oct 13, 2020 | 09:45 AM
jas88's Avatar
jas88
Did you adjust the TPS voltage to spec?
Old Oct 13, 2020 | 12:33 PM
torq'ta 5 8's Avatar
torq'ta 5 8
try this
Throttle Position Sensor Testing, Replacement and Adjustment - Ford Bronco Forum
Old Oct 14, 2020 | 03:37 PM
rclc's Avatar
rclc
Trailering
Thank so much for this procedure on TBS. I am in the process of re install TB. will keep you informed. Thank again
1986OhioF150
Jan 28, 2015 08:58 PM
Lammon
1983 - 2012 Ranger & B-Series
Aug 23, 2012 01:07 AM
mastaplan2k8
Mar 15, 2009 08:40 PM
fordtrucksj
Bronco II
Oct 19, 2008 11:46 PM
my72ford
Bronco II
Jun 5, 2006 04:20 PM
