Bronco II Ford Bronco II
tps symptoms
Old Jun 4, 2006 | 08:55 PM
my72ford's Avatar
my72ford
tps symptoms
what are the most common symptoms of a throttle pos sensor going bad? i have just finished inst a new clutch/pressure plate on my 86 b2.now when i take off it jerks really bad.it never did it before {at least not like it did today} i was wondering if the tps is on the way out..any ideas is greatly appreciated as always!
dj
Old Jun 5, 2006 | 01:42 PM
87 XLT's Avatar
87 XLT
Make sure that you did'nt pinch the O-2 wiring between the engine & bellhousing.
Take 2 or 3 minutes and pull the codes, if the TPS is bad you'll get a 53 "TPS voltage too high."
Or a 63 TPS voltage too low."
Old Jun 5, 2006 | 04:20 PM
my72ford's Avatar
my72ford
i know it's not the o2 wiring,i replaced all that after i installed the tranny..i will pull the codes tonight
hogan1967
Jan 29, 2011 10:25 AM
jaytuck
Dec 30, 2010 06:45 PM
900rr
Jan 20, 2007 01:32 PM
neoflee
15
Nov 6, 2005 04:17 PM
junkyardjeff
Feb 20, 2005 12:02 AM
