Cement on paint
Old Oct 13, 2020 | 05:02 AM
Bill Cunningham's Avatar
Bill Cunningham
Cement on paint
Have got what I suspect is cement splatter all down passenger side of truck tried to wash off to no avail what a mess! Any suggestions to use to get this stuff off? Thxz in anticipation for any suggestions, Bill,
Old Oct 13, 2020 | 02:36 PM
Beechkid's Avatar
Beechkid
Oh my Bill, that could be an issue at this point as the lye in the cement may have very well penetrated the paint... in essence gluing it together. I would try hot water soaking it for hours... I wish you the best of luck.
Old Jul 11, 2021 | 11:41 AM
Aftrmidnite's Avatar
Aftrmidnite
Dry Ice, and super heavy duty gloves, may pop it off. It works on Commercial HVAC Equipment. Also Chemical Guy, Aluminum Mag Wheel Acid Cleaner, Dilute down by half. There are YouTube Videos on how to use it on Clearcoat and Paint. Look up Water Spot removal from Auto Paint.
Old Jul 20, 2021 | 03:31 PM
FuzzFace2's Avatar
FuzzFace2
Vinegar is a mild acid spray it on and let it work keeping it wet.
Its what company's use to clean the glass on equipment used to spray powdered cement on the ground as part of shoring up roads & parking lots before paving.
Cement company's also have an stronger acid (muriatic acid?) they use on their trucks for cleaning cement off if they dont rinse it good.
Google search
https://www.google.com/search?q=how+...hrome&ie=UTF-8
Now I dont know what either acid would do to paint or clear coat but think I would start with the vinegar first and see how it goes.
Reminds me I have some cement spots on the hood of my work truck I want to remove, need to find a spray bottle and vinegar.
Dave ----
Old Jul 20, 2021 | 03:37 PM
ford390gashog's Avatar
ford390gashog
We use Zep Mudslide, Korkay Concrete remover or Sakrete Concrete remover spray on the trucks at work.
Old Jul 29, 2021 | 01:51 AM
Kramercd's Avatar
Kramercd
Give this a read. http://www.a-lok.com/pdf/kellysconcretedissolver.pdf Sounds like sugar water will do the trick. And I'd so so far as to use a mild acid. Pour coke on it.
brcwelding
Nov 19, 2011 06:11 AM
norvillebob
Feb 3, 2010 01:00 PM
herothc2003
Paint & Bodywork
13
Dec 5, 2006 06:06 PM
OldBlue66
Paint & Bodywork
May 29, 2006 06:17 PM
powerstroke6ltr
Paint & Bodywork
Feb 26, 2006 09:10 PM
