Sponsored by: Real Truck
Led reverse lights
Old Oct 11, 2020 | 04:00 PM
nathangray98's Avatar
nathangray98
Led reverse lights
So I just installed new led reverse light bulbs and now my left side is working and my right side isn’t working at all. Both sides were working fine when it was halogen bulbs so what could be my problem?
Old Oct 11, 2020 | 04:18 PM
Just Strokin's Avatar
Just Strokin
Did you try putting the halogen bulb back into the right side? If so, did it work?
Did you try the right side LED into the left side to see if it worked?
FYI...Diode lights need the correct polarity. If reversed, they won't work.
Old Oct 11, 2020 | 04:23 PM
AK4x4's Avatar
AK4x4
Check the polarity of the bulb, basically unplug rotate 180 degrees and reinstall. Other than that, assuming the standard incandescent bulb still works, you may have a defective from new unit. Good Luck, Russ
Old Oct 11, 2020 | 06:15 PM
Meat eater's Avatar
Meat eater
This ^^^. Plus 10 characters
Old Oct 11, 2020 | 07:01 PM
nathangray98
thank you that is what the problem was! Had no idea about that! I appreciate it
Old Oct 11, 2020 | 07:11 PM
Meat eater's Avatar
Meat eater
Glad you figured it out. FYI, not all LED bulbs are polarity specific, but some are as you’ve figured out.
Bogdeep
Oct 2, 2019 10:39 AM
ssande
Jun 22, 2017 10:20 AM
Supercab
6.4L Power Stroke Diesel
May 12, 2015 10:17 AM
fordtruck661
18
Oct 20, 2012 06:24 PM
cpearson
Mar 11, 2004 07:58 PM
