10R80 to small block ford pattern
Old Oct 9, 2020 | 07:11 PM
ford390gashog's Avatar
ford390gashog
Well the 10r80 wasn't used with the base V6 NA engine so thats out. There is no MAF on a Ecoboost engine. The PCM will not work without the full canbus, this issue is even present in the Ford 10r80 control pack for the 5.0 which costs 2k and doesn't work right. Your not going to be doing much because you don't have the base requirements to fulfill the PCM requirements. Unless you can find a way to get 4 channel speed sensor input, electric throttle body feedback and CPS I don't see the trans even trying to engage.
Old Oct 9, 2020 | 07:14 PM
Trenton Tbone Giordano's Avatar
I'll have a look and see what I can find off the trucks and I'll message everything here, I'm pretty sure two atleast are complete
Old Oct 9, 2020 | 07:18 PM
ford390gashog
Better get a whole truck and body swap it.
Old Oct 9, 2020 | 07:21 PM
Does that include all the safety like air bags and such
Old Oct 10, 2020 | 12:34 AM
raystankewitz's Avatar
raystankewitz
Body Swap
If you actually want it to start and drive, the short answer is yes. Most have done the swap by using the F150 firewall, floorpan and dash grafted into the older cab. You need to use teh dash because of CAN bus. Everything sits on the newer chassis with all sensors working. CAN bus can be an evil witch and it wants to see every input that it is supposed to see. That includes airbags and PATS. there are a few videos on YouTube of a guy that has done the swap on his Slickside F100's
Old Oct 10, 2020 | 10:42 AM
I'll have to just stick with my ms3 path I need it running and driving as it's my work truck, I'll look into the 4l80, are there any other 6 speeds , having 3 ods would probably have worked on the 300 with boost, a guy ran 7 pounds and make 400lbs of torque at 2k and I'm gonna do a weekend rebuild for 14-17 lbs of boost but 500+ rpm not to stress the motor but do you have a link to that f100 I'd like to see it
Old Oct 10, 2020 | 05:08 PM
torq'ta 5 8's Avatar
torq'ta 5 8
I believe this one
1966 F100 EcoBoost Engine Swap (EcoBoosted) - The Garage Journal Board
Old Oct 10, 2020 | 05:35 PM
Originally Posted by torq'ta 5 8
Thank you for that, do you know if the megasquirt controller would work with the can bus or no, I would like the 10spd for keeping the best towing but also the best gas mileage, I'd go with a c6 if that's the absolute final option, I managed to source a 4L80 for 200$ in decent condition out of a 2500 gmc
Old Oct 10, 2020 | 05:39 PM
ford390gashog
A 4L80 is a easy swap and the controller is cheap.
Old Oct 10, 2020 | 05:52 PM
Theres also a 6l80e is it the same compatability wise as the 4l80? If not I'll just run that one
Old Oct 5, 2021 | 09:03 PM
GingerDangerRanger's Avatar
GingerDangerRanger
I will be boosting the 300, I'm waiting on my megasquirt 3 as I'm going with coil on plug, as for transmission control, I would record what our new 2020 ranger does shifting for each gear and just kinda see if I can write an arduino code for it to shift for me based on tps and speed nothing else
I would be very interested to know if you ended up writing a code for the arduino to handle shifting. I have been considering a similar route, a 302 with an automatic transmission (a new 10 or 6 speed auto would be cool, but still haven’t ruled out using a manual T5 I already have from an s10) and 8.8” rear w/ 3.27 gear ratio, with 29” wheels. Recognizing this could be quite the undertaking; needing to get creative with the controller, I would like to go in further, if possible, and wire in paddle shifters, and create custom tunes, like eco/sport mode in newer vehicles, and switch between them with voice commands to cortana. As well as keep the speedo accurate by having that calculation run through an arduino or pie and being able to easily change wheel size in the calculation if I were to ever change wheel size. Any and all successes and failures you may have had with the arduino would greatly help me.
Last edited by GingerDangerRanger; Oct 5, 2021 at 09:06 PM. Reason: Forgot something
Old Oct 8, 2021 | 09:34 PM
bbf385's Avatar
bbf385
4R70W from a 99-03 V6 F150 would be an option. It will have the sbf bell and controllers are inexpensive.
bruno2
Apr 8, 2014 07:13 AM
stargazer
Flathead V8 & Flathead 6
Feb 8, 2004 08:46 AM
mwellner
Feb 22, 2002 12:14 AM
xyfalcon500
Feb 8, 2002 11:11 PM
elliott
Jul 27, 2001 09:18 PM
