Sponsored by: Auxito
My 2003 4.2 knocks.
Old Oct 6, 2020 | 09:24 PM
Res3567's Avatar
Res3567
My 2003 4.2 knocks.
My 200,000 mile truck is knocking at 1/8 to 1/4 throttle after it reaches normal operating temperature. I replaced the MAS, cleaned the EGR, replaced the DPFE, and cleaned the PCV. I also ran 93 octane fuel (Shell and Chevron) with injector cleaner. I haven’t replaced the fuel filter yet. The engine has plenty of power, and idles smoothly....I’m about at my wits end with this situation.....
Old Oct 15, 2020 | 11:15 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Knocking like a bearing or rod knock? . . . or knocking like pinging/detonation?
Are there any codes stored?
Old Oct 16, 2020 | 07:30 AM
Res3567's Avatar
Res3567
It’s like a pinging detonation, no check engine light. I cleaned the EGR and the PCV and now the light has come on. The guy at Autozone told me it was a vacuum leak after he had me use the scanner to pull the codes. I’m going to replace the EGR and PCV to see if that helps. But it’s a mystery to me at this point.
Old Oct 16, 2020 | 09:10 AM
formerjeepguy's Avatar
formerjeepguy
When is the last time the intake manifold isolator bolts were changed? They may be due again.
Old Oct 17, 2020 | 12:32 AM
CathedralCub
FTE Community Team
I'd guess it's a bad knock sensor.
Old Oct 17, 2020 | 05:44 AM
formerjeepguy
It's all guess work without the codes.
Old Oct 25, 2020 | 01:49 AM
CathedralCub
FTE Community Team
Definitely.
LightningWolf
Jan 16, 2010 04:54 AM
DrFord
Mar 28, 2008 01:15 PM
pursugr
Modular V8 (4.6L, 5.4L)
Sep 28, 2007 05:24 AM
MadMike150
3.8 & 4.2L V6
Jul 27, 2006 08:40 AM
96_4wdr
Aerostar
Feb 24, 2006 11:52 PM
