4.2 hesitates when stomp on gas pedal?
I recently replaced the EGR and DPFE valve due to a check engine light, I also replaced the air filter and fuel filter added a Lucas Fuel Injector cleaner to a full tank of gas change spark plugs and cables. Clear the check engine codes and though everything will be perfect now, but every time I have to step quickly on the gas to pass a car or make a quick move, the truck hesitates to go, first it feels as is something is holding it down and then it takes off, but is not a smooth running take off is very heavy going like if it's loaded, but the bed is empty.
Carny
12-18-2009 10:07 PM
oceanbuf
17
11-22-2008 06:02 PM
Fords&Farmalls
12-29-2007 02:05 PM
