Power steering return leaking
Old Oct 6, 2020 | 06:43 PM
Dweber85rc's Avatar
Dweber85rc
I noticed that the power steering on my truck had been leaking tonight. It appears to be return line from the cooler to the tank on the steel line portion-it rusted out. Napa has the correct hose for $200. Any reason I can't just use a length of 3/8 rubber hose and replace the whole line from the tank to the cooler for under $15? Being a return line it probably isn't super high pressure but wanted to check before I did that.
Old Oct 6, 2020 | 07:54 PM
2002Ex's Avatar
2002Ex
Maybe CRAPA thought you wanted the main hose?
Pump to Gear - 3C3Z3A719FA - $211.47
Return Hose to Pump - YC3Z3691DA - $37.13
https://www.oemfordpartsdirect.com/o...ose-yc3z3691da $22
Old Oct 6, 2020 | 08:21 PM
Dweber85rc's Avatar
Dweber85rc
nope. That is the suction line from the pump to tank. I need the return from cooler to tank.
Old Oct 6, 2020 | 09:34 PM
Lance Helmert's Avatar
Lance Helmert
GATES 352722 {#2C3Z3A713BA, YC3Z3A713AD} Return Line Assembly Info
Cooler To Reservoir
4 Day Delay
$98.79 From Rock Auto
But yes, I would consider replacing the whole thing with hose. There isn't really any pressure in the return line.
Old Oct 7, 2020 | 07:13 PM
Dweber85rc's Avatar
Dweber85rc
What is the right type of fluid to use? I've heard regular power steering fluid is not good for these systems
Old Oct 7, 2020 | 09:17 PM
2002Ex's Avatar
2002Ex
Motorcraft Mercon Multi-Purpose (ATF) according to AllData.
Old Oct 11, 2020 | 03:55 PM
Dweber85rc's Avatar
Dweber85rc
6ft of power steering hose, 2 clamps and 2 qts of fluid. $30. Way better than 200 for the correct oem hose. The worst part was getting to the cooler. The license plate bracket has to come off and In doing so I broke the 4 plastic clips. I used some short 1/4" lock nuts and bolts to re attach
Old Oct 13, 2020 | 09:21 PM
Lance Helmert
Power steering uses Mercon V transmission fluid
JayTheCPA
Jun 24, 2020 01:46 PM
Rembrant
Sep 26, 2017 07:00 PM
Gordesky Mco
1978 - 1996 Big Bronco
Sep 22, 2014 11:59 PM
GG63Slim
1997 - 2003 F150
Dec 24, 2013 09:59 AM
Myfreeford
Feb 28, 2011 10:06 PM
