Thanks. I'm planning to reprogram some stuff on my truck this weekend. Is what you're referring to the 'maintenance screen'? I've read that you can also enable a way to manually put the truck into a regen?
Sweet. Thanks. If you turn off auto-regen, how do you force it to do a manual?
It will prompt you to do a regen when it reaches 100%. You have to be parked to do it or you can check the auto regen box again and it will perform a regen while driving. Be prepared if you do an OCR, it sounds like a 747 with the fan at 100% duty cycle!
Thanks for the info, guys. Reps given! I'll be reprogramming the truck Sunday or Monday. High on the list is being able to see the exhaust filter, numbers over gauges, bambi mode, and police mode to get rid of the stupid horn honk when I get out of the truck while it's running!
One more question - will the maintenance window also show you when the truck is in regen, if you leave auto on? Or is that another setting?
It won't show when it's in regen, you'll just have to watch for your DPF% to drop. It won't start one until it's full or at 500 miles although if auto regen is off the 500 mile interval no longer matters.
