3M Paint Protection Film DIY
Has anyone installed the 3M PPF on the door edges where you grab the door to close it. I want to protect the edges from people who wear rings that may scratch the edges closing the door. I have seen that there are dealers that have kits to wrap certain parts of the truck but they are expensive and I'm hoping I can put a piece on and then trim it to fit.
I've had it applied to my vehicles but never did it myself. Lots of YouTube videos out there showing you the technique. Large areas and surfaces with varying curves are most challenging and require experienced technique. The door edge should be pretty straight forward. If you are not happy with the first application, it is removable. Another area you should consider is the door surface behind the door handle. It gets scratched up with finger nails.
Received 6,946 Likes
on
