badges
Old Jan 26, 2020 | 07:51 PM
fyrehose's Avatar
fyrehose
badges
My powerstroke door emblems are ready to fall off. What product do you recommend to re-attach them that doesn't mess up the paint?
Old Jan 26, 2020 | 08:34 PM
COE Guy's Avatar
COE Guy
Carefully take them off using a plastic pry tool then use 3m adhesive remover or something equal and lay them face down on a paper towel, fold the towel over the emblem and wet the paper towel with remover. Let them soak for 1/2 an hour (keep wetting if needed) and clean them off with a scraper or a razor blade. When all the adhesive is gone clean them with alcohol and let them dry. On the truck use a pinstripe remover wheel or careful scrape off the adhesive with a plastic tool and keep wetting the adhesive with remover until clean (be careful of scratching the paint). When everything is clean and dry apply 3m adhesion promoter (found at your local body shop) to the backside of the emblem and let dry 1 to 2 minutes. Use 3m 1/2 in adhesive tape (found at your local body shop) and stick it to the backside of the emblem. Press it on firmly. Take some masking tape and make a line on the door making sure it's level and straight then peel the backing off the adhesive and carefully stick it to the door following the tape line. Press it on firmly. Oh also wipe the door with alcohol and let dry before putting the emblem on. Once this is done it should hold for a long time.
Old Jan 26, 2020 | 08:41 PM
fyrehose's Avatar
fyrehose
Great. Thanks for the detailed info!
Old Jan 26, 2020 | 08:56 PM
COE Guy's Avatar
COE Guy
If any questions come up let me know.
bhmayor
Paint & Bodywork
Apr 27, 2017 09:00 AM
FX4 5.4
Feb 24, 2014 08:50 PM
02F250SCSD4x4Dgo
Apr 15, 2009 09:39 AM
Tom92F150
Paint & Bodywork
May 14, 2007 05:31 PM
1olddog2
Aug 9, 2004 12:25 PM
