Valve Adjustment/initial setting
Old Oct 3, 2020 | 01:09 PM
Kristofu5's Avatar
Kristofu5
I have a 1981 302 and It’s been difficult for me to find info on it about valves. What type of valves would be in it, adjustable, non-adjustable, hydraulic, solid, etc? And how do I set or adjust them?
Just performed a compression test, here are the numbers
#1 155
#2 165
#3 165
#4 175
#5 65
#6 165
#7 70
#8 160
Thanks in advance
Old Oct 3, 2020 | 01:55 PM
xlt4wd90's Avatar
xlt4wd90
Most likely 1.78 intake / 1.45 exhaust, non-adjustable rockers bolted down through pedestals, hydraulic flat tappet cam followers. You can decrease lifter preload using shims under the pedestals or get shorter pushrods. The only way to increase lifter preload is to get longer pushrods.
Old Oct 3, 2020 | 06:02 PM
Conanski's Avatar
Conanski
Yep that is a non adjustable hydraulic valvetrain. The low compression you have on 2 cylinders is not going to be a valve adjustment issue, it could be a broken valve spring, a chipped valve or really dirty valve seats that don't seal very well, or worn or broken piston rings. Add some oil to those cylinders and test again, if compression comes up the piston rings are the issue, if there is no change it's something to do with the valves.
Old Oct 3, 2020 | 08:33 PM
Kristofu5's Avatar
Kristofu5
I added some oil to the two cylinders and the compression shot up to 160-165 on both. Rings it is
Old Oct 3, 2020 | 10:24 PM
Tedster9's Avatar
Tedster9
Is it possible or very likely that just two out of eight cylinders would have excessively worn bores or piston rings, while the other six are reasonably good? Did the truck sit in a field for a long time or anything like that?
Old Oct 3, 2020 | 10:39 PM
yardbird's Avatar
yardbird
Those cylinders could have been washed down by gas also. Get it running, then check the compression again. Even running it just a few minutes with the valve covers off will be enough.
I have seen washed cylinders drop compression to basically zero a couple of times.
Old Oct 4, 2020 | 07:39 AM
Tedster9's Avatar
Tedster9
Ah. I wondered about that.
Old Oct 8, 2020 | 12:45 PM
baddad457's Avatar
baddad457
Read the spark plugs on those two cylinders.
adunham
Jul 5, 2006 08:27 PM
freezeplug
Jun 23, 2003 11:41 AM
cjknudson80
Apr 24, 2002 07:55 PM
