ProComp 22210 Issue?
Old Oct 3, 2020 | 04:31 PM
RoberDen's Avatar
RoberDen
Originally Posted by retnec58
If anybody had a chance, could they take a pic of the rear shackle on the front spring, please? Mine look to be only about an inch off the frame, and looked to have possibly touched the frame a coupke times.
Not an excellent photo, but here is mine right after installing V codes in the front. There is only 1" between the shackle and the frame. No sign it has ever hit the frame.
Note that there is an arch on the spring but I still have about 3 inches of travel on the shock before it hits the bump stop.
Old Oct 3, 2020 | 04:51 PM
Dweber85rc's Avatar
Dweber85rc
If you are measuring with fender flares on then you could be 1/2 to 3/4" higher than what you are measuring depending on the brand and how thick they are
Old Oct 4, 2020 | 10:34 PM
retnec58's Avatar
retnec58
I was able to install the zone 1" shackles. Got rid of my rubbing finally! Lol. Took 3" of lift. They are 35x12.5R20 on 20x10" rims with 5" backspacing. Now on to adding shims to get the pinion angles right and get the rear suspension finalized.
I took off my fender flares before starting and it did measure 26.5". It appears the springs "looking like that" is normal after install. Know it measures in at 27.5".
Thank all of you for your help. It is greatly appreciated.
Old Oct 4, 2020 | 10:37 PM
retnec58's Avatar
retnec58
Thank you. lets me know mine are normal. And seeing the V codes arched like that makes me feel better. Thank you again.
Lrrr-RulerOfOmicronP
Nov 23, 2021 10:40 AM
retnec58
Mar 20, 2021 07:41 AM
mcbrine
28
Oct 8, 2018 08:43 PM
brandon_0384
Mar 9, 2017 12:02 PM
nhill2090
Jul 24, 2007 10:39 PM
