2001 4r70w 4x4
Old Sep 30, 2020 | 07:01 PM
enriched&beyound's Avatar
enriched&beyound
Question 2001 4r70w 4x4
I going to swap out my 222k engine and trans for one that only has 96k both are 4r70w and 4x4.
when I removed the engine & trans of the donor. I noticed a pretty good leak on the end of the main transmission case & the seam between the extension housing before the T-Case.
My question is what bearing and or seal needs to be replaced on the end of the transmission?? can it be replaced without tearing everything out??
Old Oct 1, 2020 | 10:22 PM
jk080's Avatar
jk080
Transmission Rebuilder
Once the transfer case is removed off the transmission you can remove the extension housing from the transmission case, there is a gasket there and it is easy to replace, just remove the six bolts. The 4x4 extension housing is known to crack so look it over real good and use red loctite on the bolts going back together.
Amazon Amazon
Old Oct 2, 2020 | 07:24 AM
enriched&beyound
https://www.amazon.com/Transmission-.../dp/B01KCI878Q
Ok will do . But what about the seal/ bearing and seal around the output shaft??
Old Oct 2, 2020 | 08:01 AM
jk080's Avatar
jk080
The 4x4 set up does not have a seal or bearing/bushing for the output shaft of the transmission. The gasket for the extension housing and the gasket for the transfer case is what seals this section.
Old Oct 2, 2020 | 08:05 AM
enriched&beyound
So what keeps transmission fluid from leaking into the extension housing??
Old Oct 2, 2020 | 08:20 AM
jk080's Avatar
jk080
The extention housing will have fluid in it.
Old Oct 5, 2020 | 04:45 AM
enriched&beyound
IS there a particular location on the extension housing that these cracks tend to appear?? Not seeing anything right off after a good power washing
Old Oct 5, 2020 | 07:31 AM
jk080's Avatar
jk080
We seem cracked around the bolt holes mostly.
95WorkHorse
WTB - Parts & other
Nov 27, 2017 02:55 PM
bla614
1997 - 2003 F150
Jul 7, 2013 10:33 AM
trackenator
Jan 26, 2010 10:35 PM
fordguy300
19
May 20, 2008 09:23 PM
xshawx
Nov 12, 2004 10:14 PM
