Flexplate backward?
Old Sep 27, 2020 | 09:21 AM
kevinv10's Avatar
kevinv10
Flexplate backward?
I asked this in another forum, will try here also.
94 F250, 460, E4OD.
Recent installed the rebuilt motor. Now sometimes get a fast rattle sound, and a whirring sound, then it goes away for a bit, then whirring sound comes back. Rattle only seems to be on acceleration. Only does it when driving, not when parked in idle. Wondering if i put the flex plate in backwards? Or any other ideas?
​​​​​Motor was completely rebuilt, new bearings, pistons, rings, cam etc.
Thanks
Old Sep 27, 2020 | 11:12 AM
kevinv10's Avatar
kevinv10
Confirmed flexplate is installed correctly with weight and lip ring facing the motor. Issue is a rattling sound on acceleration, and a whirring noise that comes and goes. Does not do it in park at idle. Tried power braking and does it a little bit. Over 1500, it seems to go away. Transmission was supported during removal and install. Torque converter never shifted, and motor to transmission slid together smoothly.
I am at a loss here. Truck runs fine even when making noise, and no problems on gauges. Help. Help.
Thanks
Old Sep 28, 2020 | 11:24 AM
alloro's Avatar
alloro
Did you check the tranny and power steering fluids level?
Old Sep 28, 2020 | 10:52 PM
baddad457's Avatar
baddad457
Flexplate might be cracked.
Jamerian
Jan 24, 2021 01:02 PM
kevinv10
17
Sep 27, 2020 05:01 PM
fordman19762003
2004 - 2008 F150
Mar 13, 2012 10:38 PM
expy37at
May 25, 2011 10:22 PM
barnzey
Nov 19, 2004 07:34 AM
