Flexplate backward?
Old Sep 27, 2020 | 03:55 PM
kevinv10's Avatar
kevinv10
Originally Posted by Mudsport96
Do you happen to know what pistons were used like brand and part number? Was the block resurfaced at all? Some cheap aftermarket over bore pistons have the crown height shortened with the theory that the lower compression will offset the overbore. But this opens the quench gap and can lead to detonation.
good point. But, pretty sure with the whirring/ rubbing sound, it is not detonation. Kit is from a supplier I have used several times. So I believe quality is good.
Old Sep 27, 2020 | 04:54 PM
TooManyMIce's Avatar
TooManyMIce
Torque converter bolts torqued to spec? Check underneath for anything loose or close to fouling, especially around the area you were working in. I had a loose exhaust hanger on a truck that only made noise when the engine was under a certain amount of load (the engine was tilting just enough on its mounts to unload that particular mount, leaving it free to rattle around). That one had me worried, it sounded way more expensive from the driver's seat.
Old Sep 27, 2020 | 05:01 PM
kevinv10's Avatar
kevinv10
I'll check that. Thanks
'74 Ford 250 CS
39
Aug 4, 2018 10:37 AM
stephen.osborne1
Aug 18, 2013 07:55 AM
mokanf250
Jul 9, 2003 08:37 AM
