EOT / ECT high eot temp
Old Sep 26, 2020 | 03:39 PM
twcf250's Avatar
twcf250
I got the truck in 2019. I put a sinister diesel coolant filter on it as soon as i bought it. I replaced all the coolant parts minus the radiator and heater core. I did replace the thermostat
I now have a fresh engine with a new oil cooler. ARP studs.. Bullit proof diesels waterpump..I am still experiencing high deltas.
any ideas?
Old Sep 26, 2020 | 04:40 PM
Visurveyor's Avatar
Visurveyor
What are your temps? And are you running a tune?
Old Sep 26, 2020 | 05:10 PM
bismic's Avatar
bismic
In another thread you said you replaced the oil cooler.
What brand did you use and where did you buy it from?
Old Sep 26, 2020 | 06:56 PM
twcf250's Avatar
twcf250
Ford OEM... I have a bully dog and not running a tune at this time / actually I should say its set to no power
Old Sep 26, 2020 | 07:03 PM
Visurveyor's Avatar
Visurveyor
What are your delta's at idle wormed up? And what are they at say, 70 mph no load?
Old Sep 27, 2020 | 03:14 PM
FiveOJester's Avatar
FiveOJester
Need actual numbers you are seeing, and the conditions under which you are seeing them (speed, towing, ambient temp, etc). The deltas can be all over the place depending on a lot of factors.
Old Sep 27, 2020 | 05:25 PM
twcf250's Avatar
twcf250
I had replaced the Oil Cooler last year and did the engine swap at the end of August this year. delta's after warm up have been about 210 to 220 EOT and about 190 on ECT. Ambient temperature has been 75 to 95 this past week..
Old Sep 27, 2020 | 05:32 PM
bismic's Avatar
bismic
What coolant are you using?
How much flushing of the coolant system did you do before replacing the oil cooler?
Old Sep 27, 2020 | 08:55 PM
twcf250's Avatar
twcf250
Currently the coolant I am using is the Amsoil Heavy Duty https://www.amsoil.com/p/heavy-duty-...A#pills-home_0
I did follow one of previous post on flushing the coolant when I did the oil cooler last September. Not sure in regards to flushing when the rebuilt engine went in. I would have to follow up with my Mechanic. We did install a new oil cooler with the rebuilt engine. we did use the same sensors. I might replace the sensors. Unfortunately, I will not be driving much this week but will be driving into the office the following week. It's a fairly short drive 25 miles or so.
Old Sep 28, 2020 | 02:33 PM
FiveOJester
Easy check on the sensors is a cold start after sitting overnight. The ECT and EOT should be within a few degrees of each other and not much higher than ambient. Fortunately they are fairly easy to change if needed.
Old Sep 29, 2020 | 03:51 PM
twcf250's Avatar
twcf250
yes they are and I am ordering those. Havent been able to take the truck on a long drive so the numbers can be skewed... My first long trip will be nov 13th
Old Sep 29, 2020 | 03:52 PM
twcf250's Avatar
twcf250
Just paranoid i guess after the engine swap
Old Sep 30, 2020 | 11:31 AM
ChuckV's Avatar
ChuckV
I have an 06. Got SCT Livewire to monitor things. Deleted. Had high oil temp. Did coolant flush with Fleetguard Restore and Restore plus. Installed new ford oil cooler. Replaced ford gold with Rotella elc. Deltas still not great. Did 2 oil cooler back flushes and installed xdp coolant filter. Deltas are now good. A lot of particles still came out on the back flushes. Changed coolant filter after 30 days and coolant filter is catching a lot of particles. Deltas are below 9 on highway at 70 mph after warmup drive of 20 mins. 75mph it’s about 10. Hope that helps.
Old Sep 30, 2020 | 11:42 AM
Excurvelle's Avatar
Excurvelle
This is what I am seeing too. IDK how people see 2-3 delta.
Old Sep 30, 2020 | 01:30 PM
Visurveyor's Avatar
Visurveyor
I to have the 8 to 10° delta difference at 75 mph. I have 4 to 5 around town and it seems great to me. 3 to 4 at idle.
