engine help
Old Sep 28, 2020 | 06:15 PM
Franklin2's Avatar
Franklin2
It's ok to have rtv in place of the rubber valley gaskets on the ends, and around the water ports up front. Not ok around the air/fuel ports. I tried it once, the fuel turns the rtv to a green goo. They tell you on the tube not to use it around fuel, but I had to try it anyway.
Old Sep 28, 2020 | 06:20 PM
Brandon England's Avatar
Brandon England
idk wat im gonna do the older gentleman that i got it from did all the work and wired it up to run like a chevy idk if im gonna save it or just go different route it 2 nice of a truck to just shove out on my dads property and let sit hopefully i can save it it had a hack job done with it
Old Sep 28, 2020 | 06:33 PM
Brandon England
Old Sep 28, 2020 | 06:37 PM
Franklin2's Avatar
Franklin2
The machine shop will give it the once over very quickly and tell you the scoop.
Old Sep 29, 2020 | 08:15 PM
GLR's Avatar
GLR
And, Thank you very much for your service to our Country.
Old Sep 29, 2020 | 08:46 PM
Brandon England
thanks for you support
Old Oct 8, 2020 | 07:51 AM
Brandon England
i found a roller motor out of a 1990 f150 was wondering if i was to convert to carb would u have to change the heads too
Old Oct 8, 2020 | 08:04 AM
Thisobsfe's Avatar
Thisobsfe
no you don’t have to change the heads, you can if you want to, might be more beneficial to keep the heads on the 1990 motor since they will be e7
Old Oct 8, 2020 | 08:09 AM
Brandon England
ok thanks i may get the motor its good deal for a running engine i have intake and carb off my other motor
Old Oct 8, 2020 | 10:12 AM
matthewq4b's Avatar
matthewq4b
If the engine is the original it won't be a roller cam in 1990. Besides intake you will have to swap the front timing cover also.
Check the block casting number it will need to be an F4 block to be a roller cam block.
Old Oct 8, 2020 | 11:14 AM
yarddogg77's Avatar
yarddogg77
I've saw a whole lot worse than the pics you are showing of your motor. Is it cracked?
Old Oct 8, 2020 | 12:45 PM
Brandon England
not that i can tell but will take ti machine shop here soon hopefully and get the answer on it and ok ill look for that im just weigh my options 9n everything trying to figure out what route to take
SmackDaddy
Nov 27, 2019 08:31 PM
J Scott
Mar 20, 2018 04:09 PM
df85732
Sep 18, 2017 01:03 PM
Kahunajohn
Jan 1, 2015 11:52 PM
Cisco81
Oct 6, 2004 09:45 AM
