Needing some help codes 33 and 44
Old Sep 19, 2020 | 09:09 PM
ELI 173's Avatar
ELI 173
I recently bought a 93 f150 with a 302. It started pinging and running rough. I’ve replaced the map sensor and the pinging stopped but it’s still running rough and codes 33, egr not opening, and 44, thermactor system fault. What could be causing my issue and where to start diagnosing?
Old Sep 19, 2020 | 09:19 PM
kevinv10's Avatar
kevinv10
I would start by checking all your vacuum lines. After that, pull negative battery cable for 5 to 10 minutes. Reconnect. Bring motor up to temperature. Insure ALL electronics are off. A/C, radio, and check codes again. Both those codes sound like a broken vacuum line somewhere. I'm sure someone with more knowledge will check in soon. But, try these simple steps first.
Old Sep 21, 2020 | 06:55 AM
rla2005's Avatar
rla2005
How did you pull the codes? Count flashes or a code reader?
A 1993 model year truck will most likely display three digit codes, but there is still a possibility for it to display two digit.
Old Sep 22, 2020 | 09:25 AM
ELI 173's Avatar
ELI 173
I used a code reader
Old Sep 22, 2020 | 11:34 AM
rla2005's Avatar
rla2005
Thanks for confirming two digit codes.
Code 33 indicates the computer is not seeing the EGR opening when commanded open. Verify the vacuum lines are intact and connected.
Code 44 indicates the computer did not see any extra oxygen during the KOER tests when the thermactor system was triggered on. Is the smog pump and related valves still on the truck?
Old Sep 22, 2020 | 12:18 PM
ELI 173's Avatar
ELI 173
Yes all emissions equipment is still on and intact.
Old Sep 22, 2020 | 01:55 PM
rla2005's Avatar
rla2005
Start here for Code 44
Given you have issues with the EGR and the air injection system take a look at the metal vacuum reservoir on the passenger side fender well. It's known to rust through on the bottom.
Old Sep 22, 2020 | 09:08 PM
ELI 173's Avatar
ELI 173
it appears to be ok but I’m gonna leave it with vacuum on it all night to see if it leaks any. Any other common failure areas.
Old Sep 23, 2020 | 07:09 AM
rla2005's Avatar
rla2005
Every single vacuum line under the hood. Brake booster can cause issues as well when it leaks.
90sKid90sTruck
Oct 20, 2017 07:42 PM
Slip ford man
Feb 8, 2011 02:58 PM
true blue
May 7, 2010 10:50 AM
frey69
Jul 29, 2004 03:05 PM
