351w More power
Old Sep 23, 2020 | 08:58 AM
  #31
Bradley Freeman's Avatar
Bradley Freeman
If I was to put in a set of 1.72 roller rockers. Is that possible with the factory heads?
Any good videos that show you how to do this?
Old Sep 23, 2020 | 09:25 AM
  #32
GNR22's Avatar
GNR22
I'm sure there are videos on youtube. The factory heads (E7, GT40, GT40P, etc) use a pedestal mount rocker that is very easy to swap out with minimal hassle. I've used Scorpion, Crane, and Comp Cam's roller rockers with no issue.
Old Sep 23, 2020 | 05:00 PM
  #33
Hyperhad's Avatar
Hyperhad
I don't know how much power mine makes but I've got Comp Cams roller rockers and pushrods to match, exhaust headers, K&N air intake.
I did other things as well but those were functional as I was doing a rebuild. I got stock heads and intake and it pulls very well. Not the fastest but still fun.
Old Oct 5, 2020 | 10:16 AM
  #34
Zrt1200's Avatar
Zrt1200
I see you say no issues but which Roller rocker would you recommend for longevity on a daily driver?? Or just get the cheapest ones that you have mentioned?? I take you are using the Aluminum Roller rockers?? I see there is cheaper steel ones out there.
Old Oct 5, 2020 | 11:26 AM
  #35
GNR22's Avatar
GNR22
I've been using the Scorpion rockers the longest, but I don't think there is much difference between any of them for longevity really. If your budget is very tight, there are Proform 1.7 ratio rockers available for under $200 for the set on Summit. Part number 66878. I don't know that I've seen any steel full roller rockers on the market. Several companies makes stamped steel roller tip rockers, and there are also stainless full rollers available.
Old Oct 5, 2020 | 04:40 PM
  #36
mpw8679's Avatar
mpw8679
Originally Posted by Bradley Freeman
Looking to get some more power out of my 351w. I really dont want to spend the money to put gt40 heads and new camshaft.
I am going to put a dual 3in exhaust system and get rid of the cats. Add long headers and call it a day with that My state does not require smog for my 95 150.
How much more hp do you guys think will get out of that? What about better mpg?
Also what about putting a better aftermarket air intake? What would you recommend that is not super expensive?
What is your budget? Your not going to gain much of anything on a stock motor. The stock lower intake and heads are horrible. 3 inch duals is to big. I run 2.5 duals with my 408 stroker.
Old Oct 5, 2020 | 10:24 PM
  #37
Zrt1200's Avatar
Zrt1200
As for the steel roller rockers I was talking about these Comp Cams Chrome-moly ones.....
​​​​​​https://www.summitracing.com/parts/cca-1631-8/make/ford
Old Oct 6, 2020 | 06:10 AM
  #38
GNR22's Avatar
GNR22
These are for a 3/8" stud mount. The factory heads are pedestal mount.
Old Oct 6, 2020 | 05:58 PM
  #39
Zrt1200's Avatar
Zrt1200
Duh . I wasn't even paying attention to that. Good catch!!
Jays 07' F150
Jul 13, 2020 11:36 AM
nickels1
Feb 13, 2015 02:19 PM
79-150ranger
Oct 1, 2012 05:21 PM
panteramatt
Mar 26, 2003 09:56 PM
Jan 17, 2003 03:52 PM
