Pinion End Play Question
Old Sep 17, 2020 | 07:23 AM
624WD's Avatar
624WD
I am rebuilding a Ford 9" Differential. I assembled it after installing new bearings. The pinion assembly has some "vertical play?" when I tug on it. It moves up and down about 1/32" to 1/64" give or take and has some looseness or knocks on the ring gear when I tug back and forth on the yoke. Is this typical? or, is this where I take the assembly apart again, and add shims between the diff case and the pinion support? and that will remove this movement? or reduce it? First differential I built so I am learning this for the first time - is this movement called lash?
Looking forward to the responses.
Tom
Old Sep 17, 2020 | 05:39 PM
85e150's Avatar
85e150
Take it apart. Are you using the crush sleeve or shim method to set your clearances?
See step 12 here and search out "crush sleeve" regarding all this:
https://www.diyford.com/ford-9-inch-...mber-assembly/
You need to have a dial indicator to measure play, run out etc. You must be within specs and have an acceptable pattern on the ring gear. Otherwise you will have a short lived howler, and you will be buying bearings and probably gears again.
What instructions are you following?
aidandj
Nov 25, 2015 02:40 PM
haybayian
Aerostar
Jun 9, 2008 01:55 AM
emptyd
Sep 19, 2007 05:00 PM
therigwelder
May 27, 2005 07:24 AM
kopfenjager
Mar 2, 2005 12:42 AM
