Any gunsmiths out there?
Old Aug 1, 2002 | 05:59 AM
inliner's Avatar
inliner
I have an old Swedish Mauser that shoots really well and I wanted to install a scope on it but first I have to replace the horizontal bolt handle with one that is bent to clear the scope. What's the best way to make a clean straight cut of the bolt handle and reattach the new handle? Can I use my mig welder to attach the new bolt handle?
Old Aug 1, 2002 | 07:44 AM
TheWiz427's Avatar
TheWiz427
You can't cut and reatach the bolt handle however if you check here at www.brownells.com they might have a jig where you can carefully heat and bend it.You can also go here www.e-GunParts.com and see if they have one already bent.
Hope this helps
Wiz
An Equal Opportunity Truck Lover!
http://www.clubfte.com/users/thewiz427/index.html
Old Aug 1, 2002 | 08:03 AM
theologian's Avatar
theologian
The problem with heating or welding bits of firearms is that the heat used can make the metal brittle. Not a good thing for firearms that must withstand very great shockwaves every time they go bang. So even if you find the jig of jigs, to allow bending, NORMALIZE the work prior to using the firearm. If the links already provided do not offer a solution, then it is possible to cut off the handle, and manufacture another one, provided you have access to a TIG welder, and the expertise to use it properly. Another option you may wish to consider is a different kind of scope mount. There are custom style mounts that can place a scope out of the way of the bolt handle, by either raising it, or placing it above and to the side somewhat.
Wm
'96 F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhaust,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Old Aug 1, 2002 | 11:50 AM
fiend's Avatar
fiend
I think your best bet would to replace the bolt with a bent one. If you want to keep it in original specs, do as theologian said and try and find a diff scope mount.
Old Aug 2, 2002 | 06:23 PM
wolfmanagh's Avatar
wolfmanagh
Old Aug 4, 2002 | 01:02 AM
inliner's Avatar
inliner
Thanks for the replies, I guess like most things in life, the job is harder than it looks.
Old Aug 4, 2002 | 02:31 AM
rywegh's Avatar
rywegh
try this
http://www.gunaccessories.com/ati/SyntheticStocks/index.asp site
Old Aug 4, 2002 | 11:50 AM
theologian's Avatar
theologian
Cheaper than Dirt has a bent handled Mauser bolt, for $78.
Wm
Old Aug 4, 2002 | 04:09 PM
bgodkin's Avatar
bgodkin
Hello,
I have an old 8mm Mauser that I ran into the same problem with. I bought a sidemount scope mount through a person in Shotgun News that deals in these old weapons. If I recall right he was selling Bolt assemblies for 7mm that had the handle prebent. If he is still around I would go with one of thoses. That way all you would really have to do is install the new bolt and get Your headspace checked. The side mount scope on my 8mm is alright but I find it gets in the way just about everytime. Another company I saw had a mount that replace the top forearm on them and used a long eye relief scope. It has been a year and a half since I messed with my weapons but I would just surf through shotgun news and see what You can find. Take care.
Brad Godkin
1986 F350 XLT
CC/SRW 6.9 auto
monsterbaby
Mar 9, 2010 01:18 PM
woogs
Oct 3, 2008 11:41 PM
Tomcat7742
May 29, 2007 10:56 PM
mark a.
Apr 23, 2006 03:15 PM
Momudder720
Feb 15, 2005 09:35 PM
