Front end suspension
Old Sep 14, 2020 | 08:54 PM
StarFox's Avatar
StarFox
I am replacing the struts on the front end of my 2008 4WD with 200k miles on it. Thinking about doing ball joints and such too and was looking for opinions on getting polyurethane bushings and ball joints but using the stock control arms. Thoughts on that? Better to buy new control arms? I am wearing out the tires so I know I need new parts.
Old Sep 15, 2020 | 06:19 AM
wheelerfreak's Avatar
wheelerfreak
Upper ball joints are replaced with the A arms and come with bushings. I just bought new MC upper A arms when I replaced mine, didn't go with Poly bushings. Lowers, you can do just the balljoints, but you'll need a press to get the old ones out and you'll have to replace the bushings. I just bought complete MC lower A arms that had the bushings and new ball joints. Look in to your wheel bearing/hub and 4wd actuator and make sure they are good. You'll have to pull those out anyway to do the lower A arms so nows the chance to replace them if they are worn also.
Old Sep 15, 2020 | 09:50 PM
StarFox's Avatar
StarFox
Thanks, hadn't thought of the 4WD actuator....
Old Sep 15, 2020 | 11:16 PM
Lime1GT's Avatar
Lime1GT
I wouldn't use poly bushings if you live in a cold climate.
formerjeepguy
1997 - 2003 F150
Apr 21, 2017 07:52 AM
Hybris
1997 - 2003 F150
Jul 3, 2010 09:12 AM
shadetree01
Oct 28, 2008 03:56 PM
big315
Dec 5, 2007 07:02 PM
kmoss69
1997 - 2003 F150
Sep 24, 2005 05:46 PM
