Brake pedal hitting column
Old Sep 14, 2020 | 09:52 AM
F100wish's Avatar
F100wish
I have a CPP frame mounted master cylinder for my brake pedal and an Ididit column. The brake arm when fully depressed comes very close to the column but with a pedal pad mounted it touches. I know the brake arm is adjustable for height but I want to ensure the arm clears the column. What I am asking is:
What was your solution if you had the same problem with your brake pedal pad hitting the column when fully depressed.
I did a forum search and didn't find any solutions, and I have considered a) just adjusting brake arm to raise the pedal pad higher b) extending brake arm ear and retapping the hole
c) moving column is not an option I want to pursue as steering is pretty much wrapped up. d) making a new pedal pad with offset bolt e) having arm bent at a fabrication shop.
Thanking in advance for your solutions to this problem (pics are also very helpful).
Old Sep 14, 2020 | 10:57 AM
Gicknordon's Avatar
Gicknordon
I have clearance issues with my stock pedals and larger transmission tunnel and ended up heating and bending the arms to gain clearance.
Old Sep 14, 2020 | 12:15 PM
F100wish's Avatar
F100wish
Nice work, that really solved your problem. I will have to look into heating and bending. Thank you.
Old Sep 14, 2020 | 03:30 PM
moejr's Avatar
moejr
I had to heat and offset the pedal arm to clear the column and adapted the original round pad.
Old Sep 14, 2020 | 03:48 PM
yamagrant's Avatar
yamagrant
Mine did the same thing. I just bent the pedal arm. Good luck!
Old Sep 14, 2020 | 04:26 PM
52 Merc's Avatar
52 Merc
I would caution against raising the pedal as an option for creating clearance, or any other reason. It's already a long way to lift your foot from gas pedal to brake pedal in stock form, and comparing to modern cars, that's becoming an abnormal movement. In an emergency situation when you need to get to the brake pedal in a hurry, every wasted millisecond of motion could prove unfortunate or deadly. If you can find a way to lessen that transition, you will be better served by it.
Old Sep 15, 2020 | 11:36 AM
bigjob56's Avatar
bigjob56
heat and bend or offset\rectangular pedal pad gives you more room for your work boots.
Old Sep 15, 2020 | 10:38 PM
F100wish's Avatar
F100wish
As far as the offset pedal pad goes, does someone make these or did you fabricate your own?
Old Sep 15, 2020 | 10:52 PM
bigjob56's Avatar
bigjob56
macs makes one for earlier fords.. https://www.macsautoparts.com/early_...kup-truck.html
also, pretty straightforward to fabricate.
newguy399
May 9, 2016 09:38 AM
DavidTCope
Apr 13, 2016 10:30 AM
comochja
Apr 28, 2006 04:28 PM
Lwlandy
16
Oct 1, 2005 09:25 AM
hirschi
Mar 20, 2002 07:02 PM
