Truck started missing
Old Sep 11, 2020 | 08:43 PM
Mikec35's Avatar
Mikec35
I was driving my truck and it felt like it was missing around 30 mph going up a hill with an easy throttle. It did it twice, seems like I was able to throttle it through the second time, kinda hard to tell because it happened pretty quick. I didn't get a check engine light. Any idea what I should start checking? I thought possibly water in my fuel, I'll drain the bowl and take it on a drive to see if it reoccurs.Thought maybe transmission stuttering but it was rebuilt 8,000 miles. I'm at 269,000 miles and truck has run great, I don't know the previous owners history. Any advice appreciated. Thank you
Old Sep 11, 2020 | 11:02 PM
BWST's Avatar
BWST
Got Data?
Might have a pending code for that miss. These will not trigger the CEL. I would recommend reading codes with Forscan or Forscan Lite and an OBDII dongle. UVCH on one side or the other might be coming loose.
Old Sep 12, 2020 | 05:36 PM
Mikec35's Avatar
Mikec35
Thanks Jeff. I've got Forscan and the dongle. Just need to take the time to figure out how to use it. I took the truck for a 20 mile round trip today and it worked fine, no misses.
Old Sep 16, 2020 | 05:53 PM
carltonwebb's Avatar
carltonwebb
check engine oil level while you are looking. Its free and could cause similar issue when truck is cold (below normal temp bracket).
Old Sep 17, 2020 | 07:52 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
What was fuel level ? Hutch mod or factory screens?
Old Sep 17, 2020 | 09:19 AM
Brother Les's Avatar
Brother Les
This may not happen again for thousands of miles (or get worse). With that amount of miles, o-rings are breaking down. Hit a bump and a connection at the HPOP may move and allow a leak. Do you have any oil or fuel in the valley?
Old Sep 18, 2020 | 09:57 PM
dmd's Avatar
dmd
Blowby level change dramatically?
MadMaxx84
Jul 13, 2020 11:10 AM
maverick22
Jul 22, 2013 11:55 PM
Deadeye1445
Nov 11, 2011 09:59 PM
952X4
6.7L Power Stroke Diesel
25
Oct 22, 2011 07:56 AM
sterling
Jan 11, 2005 12:02 AM
