Broke bolt
Old Sep 9, 2020 | 10:09 PM
CJMOStang's Avatar
CJMOStang
Broke bolt
I went to drop in a new distributor and broke off the hold down screw with very little torque . What’s the best way to get that out without a torch?
Old Sep 9, 2020 | 10:40 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I don't know how much access you have to the bolt but, I usually place a flat washer over the broken bolt and weld it to the bolt. Assuming you have enough there. Then I weld a nut to the washer. Let it cool and "usually" it will spin out. Drilling it and using an easy out sometimes works. Not my first choice though.
Old Sep 9, 2020 | 11:30 PM
Fomoko1's Avatar
Fomoko1
If it`s not overly tight sometimes running the drill in reverse works.
Old Sep 10, 2020 | 04:07 PM
Mixer man's Avatar
Mixer man
Left hand drill bit.
Old Sep 10, 2020 | 05:14 PM
AllenV's Avatar
AllenV
This is an excellent approach! I have been staring at a rusted and broken off bolt in my radiator support bracket for some months now. The welded washer may be just the ticket. I imagine the heat will crack the rust as well.
Old Sep 10, 2020 | 05:54 PM
seaves46's Avatar
seaves46
This is usually the method i use also , as you say the heat from welding usually cracks the bolt loose .
I've had stuck bolts screw out almost with no effort at all after using this method .
Old Sep 11, 2020 | 08:58 AM
EBEAR's Avatar
EBEAR
If you broke it putting it back in it's usually just a flawed bolt or too much muscle which means it's not likely seized in the threads so a reverse drill bit should walk it out if not you already have the hole for an easy out . I personally only use welding as a last resort although as mentioned welding works well with rusted in - seized bolts .
AbandonedBronco
17
Feb 5, 2020 03:28 PM
wileyinohio
18
Aug 12, 2016 05:40 PM
Fordy Four
May 7, 2008 11:07 PM
snipa
Nov 17, 2004 01:05 PM
tweakingit
Sep 29, 2003 07:34 PM
