Caliper Bolt
Old May 6, 2008 | 11:09 PM
Fordy Four's Avatar
Fordy Four
Caliper Bolt
The bolt that holds the key in place on one of my calipers had the head snapped off. Does anybody have any tips for drilling out the rest of the bolt?
I tried to drill a pilot hole and use a device to get the bolt out and still maintain the original thread but I seem to have buggered that up.
Old May 6, 2008 | 11:25 PM
Hillcrest#9's Avatar
Hillcrest#9
Yup! I broke the same bolt on the drivers side. Damm hard to drill them bolts out, Buggered mine up also. Ended up drilling out what I could then rethreading the hole and using a standard bolt, Don't seam to cause any problems.
Old May 7, 2008 | 09:37 AM
duste's Avatar
duste
You can tap and drill a new hole in the other side the slide bar where the second hump is, or just slide it over 3/4 of an inch and tap a new hole. Broke one off myself, then drilled the bolt, broke the bit off in the bolt, got the bit out, finished drilling hole , then broke off easy out in the bolt ( they don't come out). Then got mad , dented firewall with hammer and went in house. Next day drilled new hole on the other side, put in new bolt and then fixed firewall. Thought you may like that, it was 20 yrs ago and now have developed patients.
Old May 7, 2008 | 12:45 PM
OldMetal's Avatar
OldMetal
Heating the area may help get the broken part out.
Put some anti-seize on the threads of these bolts.
Old May 7, 2008 | 05:36 PM
MikeWire's Avatar
MikeWire
Yep, soak it in PB blaster, put some heat on it and attempt to get it out. I had to do that to get my drag link out the other day, and it popped out after torching it. A stubborn bolt will do the same.
Old May 7, 2008 | 11:07 PM
4x4 Bart's Avatar
4x4 Bart
I have had good luck with left hand drill bits.
BjornF16
Nov 18, 2016 03:17 PM
Pothole
Apr 9, 2011 08:48 AM
F-250 restorer
Oct 30, 2010 09:30 AM
pmerr
Sep 18, 2009 02:57 PM
moritz1024
1978 - 1996 Big Bronco
Oct 9, 2004 10:52 AM
