Steering column problems
Old Sep 8, 2020 | 06:28 PM
Rdytodive's Avatar
Rdytodive
Does anyone have a diagram of a 1975 automatic steering column? I can not figure out what holds the tension on the shifter collar to keep it seated in the shift lever at the bottom. Need to know what I am missing or what I’m doing wrong. Thanks for the help.
Old Sep 8, 2020 | 07:04 PM
72rtchallenger's Avatar
72rtchallenger
Whats the problem with your shift lever ?
Old Sep 8, 2020 | 07:41 PM
Rdytodive's Avatar
Rdytodive
It will not shift. It just moves freely. The collar is attached to the shaft but the shaft wont lock into the the shifter lever at the bottom.
Old Sep 8, 2020 | 07:50 PM
72rtchallenger
that lever slides over a place like a key way to keep it in position, its welded on , they can shear and then lever movers freely an will not shift properly
Old Sep 8, 2020 | 08:03 PM
72rtchallenger
Old Sep 9, 2020 | 06:42 AM
Rdytodive's Avatar
Rdytodive
Thank you I figured that out, but the spring keeps popping it back up. So am I putting the spring in the wrong position?
Old Sep 9, 2020 | 06:22 PM
72rtchallenger
I am unsure of exact problem , are you trying to put all back together and the top collar is spring up ? As I was thinking the bottom cant move up without the top collar locking in position , which are two retaining bolts that have flat square shape heads that have to go in a certain position to hold it in place when the nuts are installed , or is there another issue ?
Old Sep 10, 2020 | 05:45 AM
Rdytodive's Avatar
Rdytodive
Thanks everyone it ended up someone had pushed the shifter collar down way to far. I put a new one on it and it works now.
Indybeer
Sep 12, 2018 08:46 PM
Rambler1990
Apr 22, 2018 05:51 AM
Ryan3345
Feb 7, 2016 06:30 PM
abriel68
Apr 29, 2013 02:52 PM
dogman
Jul 4, 2005 05:44 PM
