engine stalls
Old Sep 7, 2020 | 11:44 AM
Alex_95_F350_Powerstroke's Avatar
engine stalls
Engine is running real rough I have to hold the gas pedal all the way to the floor just to keep the engine running. if I try to drive it it won’t go no more than two or 3 mph holding the gas pedal all the way. The engine feels like if it’s only working with four injectors. I have both fuel tanks filled with diesel. I replace the mechanical pump at the block. Also replace the ICP. No check engine light has came on. does anyone have an idea of what can it be ?
Old Sep 7, 2020 | 12:49 PM
96 OBS's Avatar
96 OBS
Check the wire harnesses at the valve covers for melted puns or bad wires
Old Sep 7, 2020 | 12:53 PM
Edgethis's Avatar
Edgethis
Make sure the filter is clean and bowl is full. I imagibe you did that when the pump was replaced. Just double checking.
Old Sep 7, 2020 | 04:49 PM
farmert's Avatar
farmert
I second the valve cover harness and pins in the valve cover gasket. It may also be the under valve cover harness. The IDM will shut one bank down to protect itself if it senses a short in the circuit.
Old Sep 7, 2020 | 05:37 PM
thank you guys i will take a look at the valve covers tomorrow and will let you guys know what i find !
Jairo Orellana
Aug 19, 2020 09:15 PM
forresterdobbs
Oct 10, 2010 03:50 PM
bdavis1369
Aug 5, 2010 11:09 PM
Cobratodd
Apr 9, 2010 09:43 AM
Finger mullet
Jan 3, 2008 11:36 AM
