Sponsored by: Real Truck
Check Engine Light / Stalling Issue HELP!!
Old Dec 31, 2008 | 08:39 PM
bdavis1369's Avatar
bdavis1369
So Yesterday I got a check engine light...but I didnt get the chance to have it scanned....
Today I hook up my plow and go out plowing and the truck stalls almost every time I come to a stop or shift into reverse. Also, it feels like the gas pedal at a stop isnt working. When I am stopped and in neutral....i give it gas slowly and steadily and by the time the gas pedal is like halfway to the floor the idle starts to rise....VERY unresponsive. When I am actually moving the gas pedal is very responsive.
I dont know if the three issues (Check engine / Stalling / Gas Pedal response) are even related but I thought I would see if anyone has any ideas.
PS i have a 2005 f250 V10 with 42K
Thanks!!
Old Dec 31, 2008 | 10:35 PM
bayou barataria's Avatar
bayou barataria
I had the same problem on my last truck, it turned out to be the fuel pump. Have you checked the fuel filter?
Old Dec 31, 2008 | 10:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
Throttle position sensor?
Old Dec 31, 2008 | 11:16 PM
bayou barataria
Check out the scan guage web site, I got a scanner for less than $100.00. It is not fancy, but it works and it will re-set the cel.
Old Jan 1, 2009 | 09:15 AM
projectSHO89's Avatar
projectSHO89
Without the fault code(s), anything anyone tells you is a pretty much worthless guess.
Get it scanned.
Steve
Old Jan 2, 2009 | 09:50 AM
bdavis1369's Avatar
bdavis1369
Ok, I brought the truck to a repair friend of mine with a $4000 Snap-on scanner. He got a code Idle Air Control Sensor....so I called ford told them I have a 2005 V10 and they said thre is no IAC sensor in that vehicle that its "drive by wire". They want $140 to diagnose the prob but cant get to it for 1.5 weeks. ANY HELP WOULD BE GREATLY APPRECIATED truck keeps stalling out at a stop!!
...THANKS
Old Jan 2, 2009 | 01:25 PM
bdavis1369's Avatar
bdavis1369
bump......
HELP GUYS!!!!
Old Jan 2, 2009 | 01:47 PM
BareBones's Avatar
BareBones
Well I have no expertise in this, but I'll throw this out for debate, if only because I personally like to eliminate the simple explanations before paying for the expensive ones....
Could the injectors be partially plugged/ restricted? It seems to me that this fits your description, where pressing on the pedal at idle is very sluggish. Given that you don't apparently have any other choices, I'd throw a good concentration of cleaner in the gas and rev it up good on some interstate ramps and see whether there's any improvement?
Old Jan 3, 2009 | 10:57 PM
bayou barataria
1 1/2 weeks is fast around here, here they make you leave your truck for the entire wait time.
Old Jan 4, 2009 | 12:14 AM
Chaosracing's Avatar
Chaosracing
Try the air bypass valve. I had to have mine replaced under warranty. It kept sticking on me. It would do the same thing. But you also might want to change fuel filter.
Old Jan 4, 2009 | 03:04 AM
redford's Avatar
redford
What was the exact code?
Old Jan 4, 2009 | 03:06 AM
redford's Avatar
redford
2005+ Triton engines do not have Idle Air Control valves, or as you said, air bypass valves.
Old Jan 11, 2009 | 08:07 PM
budman325's Avatar
budman325
same thing
My 04 F350 V10 does the same thing, took it to aoyozone and they used a scanner on it, the code that came up was P0304. definition came back as misfire detected on #4 cylinder, probable causes are
1-Ignition system fault-spark plug(s),ignition wires, coil
2-Vacuum leak
3-Injector fault
4-High or low fuel pressure.
I changed the fuel filter and spark plugs and still does the same thing.
Goinna change the coil wire on the spark plug tomorrow!
How do you check fuel pressure?
Old Jan 11, 2009 | 10:11 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
check youre maf sensor . pull it out and clean it with maf cleaner might help . takes about 10 minutes .
Old Jan 11, 2009 | 10:36 PM
bdavis1369's Avatar
bdavis1369
BUT why would my truck be spitting out a code to something it doesn't even have...
Im also being told that it has something to do with the "drive by wire"....???
