Factory sub and amp replacement
It is absolutely true that you can’t simply remove the B&O amp, as so much runs through it and it uses a digital BUS signal.
It is absolutely false that you need to bypass the factory amp to install a new sub and amp.
Just grab the sub signal out of the factory amp and use that. You’ll be fine.
If you want to upgrade all the other speakers, it starts getting messy and expensive. But, for a simple sub upgrade, it’s easy peasy. Leave all the factory stuff alone; install the new stuff downstream of the factory audio gear.
Searching is your friend as this has been documented several times here.
The problem is that Ford uses Automotive Audio Bus (A2B). This is a digital signal that combines audio, various control signals, clock/timing info, and other bits of info all intertwined in a single signal. When you start interrupting this, there can be big problems. That's why various aftermarket devices are required to hack the system, unravel the various pieces of information, and parse out the audio signal for use with aftermarket amps/DSP/speakers/etc. without disrupting the other stuff. This isn't simple like it may have been in past decades.
For subs and bass, you're better off taking the bass signal post-processing ( after the factory amp)and feeding that into your AM amp. This is good enough. You then have your bass signal, weakly amplified by the factory amp. Take that signal directly into your amp (that can accept high level input) and then that amplified signal to your new AM subwoofer. And, the rest of the system is intact and free from shenanigans.
I've installed a Kicker 47KEY500.1 amp and a Kicker 48CWRT84 subwoofer. I've connected my factory subwoofer lines from the factory amp to my new aftermarket amp and then to the aftermarket sub. I have the gain turned all the way down and there is a massive amount of clipping. I had a car audio tech look at it briefly and he said he thought the now "double amplified" signal to the subwoofer was the cause of the clipping and that I should bypass the factory amp and go directly to the aftermarket sub. What are your thoughts?
If the gains are down and the volume is up at the head, I'd expect clipping (you need your sub amp to come in sooner). Check your install with a good ground and set your head volume at 10 with the EQ flat and test again. If you still have clipping. I'd suspect the amp is defective. If you don't have clipping, follow the set up on the amp owners manual for gain and input. There are hundreds of us that have done this and your audio shop guy is off the mark on this. .
A "double amplified" signal is a diagnosis that would have me running for the door. This guy doesn't sound like he understand high level signal inputs and definitely doesn't know the specifics of your vehicle. Don't go back to that shop.
Here is a thread that shows how I did my install: sub and amp upgrade, 2019 B&O system. You may find some help in how to run lines and how to set your levels on your amp to get no clipping. There are other threads here and elsewhere, too. Searching is always a good idea. System upgrades are super popular and are the same for F-150s. As I said earlier in this thread, searching through F-150 forums is helpful because the systems are the same and there are 10x more of those folks doing the upgrades. You can learn a lot if you search and read.
With that said, here's your components: a 4 ohm DVC sub and a 500W @ 1 ohm amp. That sub can either be wired for 8 ohms or 2 ohms. You want it for 2 ohms, so make sure you have that wired properly. At that point, the amp will put out 300 W. If you accidentally wire your sub for 8 ohms, then your amp will probably only put out 75 W. If you're doing that, then you're going to get wonky sound because the sub is massively underpowered at that point.
For your amp, you need to ensure that you're using the speaker level, high level signal inputs. I'm not sure how your amp is wired as I'm not familiar with the model. But, you want to make sure your amp can actually handle speaker level inputs (not all do, but most do) and that you've wired it properly.
You do not need to bypass your factory amp. That thing is probably putting out 20-30 W, max. That's right in the sweet spot of any amp's ability to handle speaker-level inputs. If you're still bothered by that, then use a line output converter to drop your amplified speaker level signal down to a low level input. AudioControl is a trusted brand for line output converters and you can read more about them elsewhere.
Finally, the amp needs proper wiring. Please tell me that you're not using factory power lines/wires to the new amp and that you ran your own 8 gauge OFC power and ground to the new amp. If not, you need to. Then you need to check and double-check those lines. What is your voltage up at the battery? What is your voltage back at the amp? If you're getting a voltage drop, then you have a wiring problem, you may be under-driving the amp, and that could be part of your issue. Same with the grounds. Ensure that you have a short, clean ground using at least 8 ga OFC wire and that it has less than 1 ohm resistance between that point and your engine-bay ground. Again, you can read more about this via my link or searching.
This should get you started.
