Sponsored by: Real Truck
Overcharging issue please help
Old Sep 3, 2020 | 11:06 PM
Sam P's Avatar
Sam P
So A couple weeks ago I noticed I had a little dip in Rpms now and then and noticed my voltage on my batteries were quite low at 11.15-12.55. I thought it might be my charging system as the guy we bought the truck from had older used batteries in it cause he didn’t really care about the truck. As well as the oem secondary alternator and a poorly reman primary. Well we changed them and the batteries as they were all reading low as well. We have brand new motor craft 850cca batteries in it now and 2 reman alternators from motor craft as well. Well now it’s reading 15.34volts steady. We are worried about an overcharging issues. As well as the instrument cluster stops working as well and the battery light comes on. Not sure if it’s related at all. But we just aren’t sure. Anyone that would shed some light is very much appreciated.
Old Sep 3, 2020 | 11:11 PM
Sam P's Avatar
Sam P
Also....
it is on a 06 f250 6.0 dual alternator setup
Old Sep 4, 2020 | 06:16 AM
Tedster9's Avatar
Tedster9
Just to be clear, What (and where) are you measuring with? Charging voltage is temperature dependent.
An accurate, calibrated voltmeter is important. The voltage at the battery posts is what counts. 15.3 is normally way too high, it would be typical at something like -20 below zero.
Old Sep 4, 2020 | 08:26 AM
redford's Avatar
redford
FTE Leadership Emeritus
There have been a bunch of "rebuilt alternator" horror stories lately. It's insane.
Old Sep 4, 2020 | 05:58 PM
99f350sd's Avatar
99f350sd
14.7 max. My ambulance regulator gives that amount. normal truck 14 to 14.5 Depends on charge of battery and load. Doesn't the computer on that engine manage the charging? The 6.0 was the first to do that if I remember..
Old Sep 5, 2020 | 09:36 AM
F350 1990's Avatar
F350 1990
Ford's design --> In the single generator system, the VR (voltage regulator) controls the lamp. In the dual setup, the PCM controls the charging system indicator, illuminates the light if a problem in the circuits is detected. The dual generators act independent of one another and rely on internal VRs.
15.5V is the target level in the design, anything higher and you've got problems with fuses, circuitry, or in the upper or lower VRs .
k9Excursion
May 20, 2019 04:33 PM
Walterg
Apr 4, 2018 04:54 PM
KHflatbed
May 31, 2017 10:18 AM
mrnascar30
Jun 25, 2012 12:47 PM
danielboone4
37
Aug 29, 2004 12:55 AM
